Old    WakePowell Chris (epic1)      Join Date: Oct 2006       06-01-2008, 7:13 PM Reply
think mine went today. Where is it? is the water pump the center pully? If it is the impeller, can I upgrade to a brass or something? ford 302. Thanks.
Old    Art (rallyart)      Join Date: Nov 2006       06-01-2008, 8:05 PM Reply
The water circulation pump is the upper center pulley. The water supply impeller is belt driven on the side of the motor low down. The circulation pump impeller is metal and not likely to fail. The supply impeller is easy to damage because it relies on being covered with water to cool and lubricate it.
If you are overheating it's most likely the supply impeller.
Old    WakePowell Chris (epic1)      Join Date: Oct 2006       06-02-2008, 10:08 AM Reply
so that suply imp. is the rubber one that often goes out, ant its houseing is has two water lines in and out to it? Thanks.
Old    Art (rallyart)      Join Date: Nov 2006       06-02-2008, 10:15 AM Reply
That's it.
Old    WakePowell Chris (epic1)      Join Date: Oct 2006       06-03-2008, 1:03 AM Reply
grasias senior
