Froggy? I read another post that said something about the set up for a progressive edge(load and release trick). For a HS trick , cut out toe side fast so you advance on the boat,then turn your board in when you are going the same speed as the boat so you can load and release late at the wake.If you turn in too quick you'll have slack line and if you wait too long you'll have too much load and too much speed when you hit the wake(or get pulled off edge).I think I do this already but never really thought about it much.But especially on 360's ,once in a while I do have too much tension and get yanked.It makes sense but I never heard this before.
