Old     (jpuckett)      Join Date: Apr 2005       05-18-2008, 6:19 PM Reply
I just helped a friend of mine install his FAE system on his Centurion Typhoon. We took it to the lake to try it out and what a difference.
The only down side we could find was that the boat had a small rooster tail at normal speed behind the swim platform, and it throws water up between the transom and the platform. Is this normal or have we done something wrong?
Old     (rallyart)      Join Date: Nov 2006       05-18-2008, 6:23 PM Reply
Mine does that too. You could try tilting the down pipe a bit further back but I don't know if that's going to make much difference.
Old     (shellyrn)      Join Date: May 2006       05-18-2008, 9:57 PM Reply
We just cut a piece of plexi and attached it to the top of the FAE to stop the spray between the platform and transom.
Old     (chpthril)      Join Date: Oct 2007       05-19-2008, 12:58 AM Reply
I moved mine in as close to the TAPS plate as I could and spray is gone.
Just play around with the angle of the down pipe, but use a paint pen and put a couple of index marks on the pipes so you know where you started.
Old     (ord27)      Join Date: Oct 2005       05-19-2008, 6:56 AM Reply
does anybody know if the system is available for the Malibu yet?.....and still be able to use the power wedge?
Old     (rallyart)      Join Date: Nov 2006       05-19-2008, 11:22 AM Reply
I know they ran some prototypes but you'd have to call them.
