Old    Joe C (chrzanowski5)      Join Date: Aug 2002       05-13-2008, 8:37 PM Reply
One quick question, in what position should the trailer tongue be when bleeding surge brakes? Extended or applied?
Old    Aaron Ware (99_slaunch)      Join Date: Oct 2005       05-13-2008, 8:43 PM Reply
Level or up. The master cylinder should be the highest point of the brake system.
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       05-13-2008, 8:46 PM Reply
Applied, crack the bleeder and bleed fluid then close bleeder and then let off tongue. Repeat till no air. Topp off cylinder as you go so it won't get too low and allow air back into the system.
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       05-13-2008, 8:50 PM Reply
Don't even bother trying to gravity bleed. The lines run up from the axle to the wheel cylinder and would bleed hella slow if at all. Pressure bleed by yourself or manualy with two people.
Old    david rogers (davee22ve)      Join Date: Nov 2007       05-13-2008, 9:26 PM Reply
On my trailer if you take a flat blade screw driver under neath you can stroke the piston and it has somthing that holds it applied for you. go back bleed one break caliper. then release it and do it all over again. takes a while and is a lot easier with two people.
Old    Joe C (chrzanowski5)      Join Date: Aug 2002       05-14-2008, 4:39 PM Reply
I forgot to mention that I was planning on using a Mityvac hand held vacuum pump.
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       05-14-2008, 7:19 PM Reply
With MityVac you want it in the extended position...
Old    Joe (superairdawg)      Join Date: May 2003       05-15-2008, 4:13 AM Reply
If you bleed by hand it depends on whether you stoke the cylinder with a screwdriver, or you actually move the whole actuator with a lever (2x4 or similar). Either way, the actuator should eventually extend because of the spring contained inside.
From everything I've read and from my experience it'll make it easier if your master cylinder is lower than the bleed ports, so air bubbles are forced upwards.
