Old     (blazeremt89)      Join Date: May 2007       05-13-2008, 9:20 AM Reply
i have a 90 180 four winns horizon... is it worth putting in a 4 blade prop? will it make wakeboarding easier?
Old     (rallyart)      Join Date: Nov 2006       05-13-2008, 11:34 AM Reply
I put a 4 blade Mercruiser Vensura stainless prop on my 18' I/O and was very happy with it. There are plastic caps just behind the blades that you can drill or replace to vent a bit of exhaust at slower speeds. That allows you more slip on the prop at slow speeds which helps acceleration. I tried the High-5 also but it was not better for my boat.
The improvements over a 3 blade stainless were better acceleration, better ability to hold speed, and less likelyhood of cavitation on corners. I'm sure it would be worth it, especially if you are using a 3 blade aluminum now.
Make sure you figure out what pitch you want your new prop to be.
