Old    Cory McLean (kikitlo)      Join Date: Jul 2005       05-12-2008, 2:02 PM Reply
Ok, Where the hell are the screws to remove the foot rest in my 07 LSV. I want to put in a sub box but am struggling to find the screws for it. I see the black block near the center walk thru side but where are they on the starboard side.
Thanks in advance
Old    VLX Envy (cavlxenvy)      Join Date: Aug 2007       05-12-2008, 2:39 PM Reply
They should be on the very bottom. I want to say there are three to four screws.
Old    Steven Spotts (sp0tts)      Join Date: Jun 2004       05-12-2008, 3:05 PM Reply
I pulled at least 10 screws out of the kickpanel in my 08 VLX. They bury them and screw the sh*t out of it. They are hard to find, really have to run your fingers or bit through the carpet to find them. Once you get most of them out there may be a couple you can't find. Once I got most of them, I gently used a pry bar to pinpoint where there were still screws holding and then found them and backed them out. Took much longer than I thought it would though.
Old    Cory McLean (kikitlo)      Join Date: Jul 2005       05-12-2008, 3:25 PM Reply
Thanks guys, I will give it another look this weekend.
Old    Anthony (echo_parker)      Join Date: Feb 2008       05-12-2008, 5:21 PM Reply
Use a strong magnet to locate the screws
Old    rodney (azwakekid)      Join Date: Apr 2005       05-12-2008, 5:50 PM Reply
the screws should be stainless steel so a magnet would not work. just got to find them in the carpet.
Old    dhcomp (dhcomp)      Join Date: Jun 2003       05-12-2008, 8:08 PM Reply
I actually used a stud finder that works for metal studs. Its a BITCH to find them, the screw heads are silver, the carpet is grey, and the carpet base material is silver. It took me FOREVER.
Good luck!
