Old     (azwakekid)      Join Date: Apr 2005       05-04-2008, 2:36 PM Reply
has anyone ever added a shower in there boat? im am lookin to do one and there not a lot talked about? is it worth it? where did you get your at?
Old     (trdon)      Join Date: Sep 2007       05-04-2008, 2:47 PM Reply
I have been thinking of doing this too. I am up for a DIY idea but I have one of my own right now, but would like some ideas to do it too.
Old     (h20jnky)      Join Date: Mar 2003       05-04-2008, 3:02 PM Reply
showers are nice if like to you enjoy early season rides in a cold climate.. does arizona get cold? anyhow, they aren't used that often but nice to warm up that thin layer between suit and skin before entering cold water.. also, nice to have around after exiting cold water to warm up the digits and diggers.. it is also just one more bump option you can get with nada when you decide to sell or trade your ride.. here is a link to skidim:
http://www.skidim.com/prodinfo.asp?number=101-S-C
install is easy if you've got good maneuverability around engine compartment..
good luck!
Old     (cody_08_lsv)      Join Date: Feb 2008       05-04-2008, 3:20 PM Reply
^ this is the same shower I have on my new malibu and I am in love with it I fill up the closetoe boots before I ride along with my wetsuit then when getting out I could sit on the back of the boat all day in the warm water on me it was well worth it for me. I also like the stream setting it makes a pretty good squirt gun! haha
Old     (pwningjr)      Join Date: Apr 2007       05-04-2008, 6:22 PM Reply
http://www.wakeworld.com/MB/Discus/messages/65921/84572.html?1065589943
Old     (pennery)      Join Date: Jul 2006       05-04-2008, 8:28 PM Reply
Just call Heater Craft directly.. They are great to deal with..
http://www.heatercraft.com/
Old     (etakk7)      Join Date: Apr 2006       05-04-2008, 9:04 PM Reply
I just bought a Heatercraft 101 model for my 205V for $199 from boatersoutlet.com. Everything I've seen is that a DIY is around $150, so I thought it was nice to have the real thing. Installation hasn't been fun, because I've been pretty careful cutting fiberglass through the transom! For the Minnesota climate, I'm really hoping I get a ton of use from it and can extend the season.
Old     (n1n2)      Join Date: May 2008       05-04-2008, 9:19 PM Reply
Question: Is there a hot/cold shower system that is compatible with a ZR6 operated with fresh water closed cooling system? If not, is it possible to install via water cooled exhaust port (if there is such a thing). If not, anybody have solutions?
Old     (billhall)      Join Date: Jun 2006       05-04-2008, 10:56 PM Reply
I'm a Nautique dealer and NO ZR6 was ever compatible with a shower. On the invoices it said "ZR6- No shower option available" or something along those lines. You still may be able to design one yourself though...
Old     (yubasanger)      Join Date: Jul 2007       05-05-2008, 2:19 PM Reply
So how do they do it in offshore boats or what about Wakecraft? The shower just needs a heat exchanger that will be installed in the closed loop cooling system. But itís not cheap runs $514.00. Part# 98605, MFR# 120-s-c
http://www.go2marine.com/product.do?no=74819F
This is the heat exchanger. Keeps shower water and coolant separate.
Old     (brucemac)      Join Date: Dec 2005       05-05-2008, 3:17 PM Reply
erik
can i ask a dumb question? why do you have to cut into the transom? i thought all the shower stuff was in the motor box and one of the rear lockers???
Old     (etakk7)      Join Date: Apr 2006       05-05-2008, 8:17 PM Reply
Bruce, on the 205V hull there is a cutout in the transom for a factory option shower. That way you can control it from the swim platform without opening the rear hatch. It's a pretty cool design.
Old     (n1n2)      Join Date: May 2008       05-06-2008, 4:51 PM Reply
Brandon,
This closed loop cooling heat exchanger system seems viable. Yes, the price is high but if it's the only option, then I'll shell out (live in Northwest; wife and kids want hot shower). With a system like that, wonder why the dealers I have talked to tell me not to modify? Heater is OK, but not shower. Isn't the heater somehow coupled to closed-loop too?
Old     (deltaboy)      Join Date: Jan 2007       05-06-2008, 7:03 PM Reply
Yep ours has shower and its a ZR6 and I'm pretty sure the shower is Heater Craft.
Old     (watersnake)      Join Date: Jul 2006       05-06-2008, 7:41 PM Reply
I have the Aqautic shower listed in the posts near the top. But can't seem to adjust the temp very well...eathir to cold or scalding hot? I have adjusted the gauges. Does the boat need to be running to draw lake water??
Old     (n1n2)      Join Date: May 2008       05-07-2008, 8:47 AM Reply
Though there are many reasons why a closed cooled shower system is discouraged (like one above, so I have learned), the likely one stems from a product liability case associated with carbon monoxide poisoning. In this case a person experienced cmp while using said product above. The product worked perfectly, however. IMO, it was DA's lack of judgment that lead to cmp because he used it while sitting next to exhaust pipe. Next step: lawsuit. Brilliant. Blame product designers and manufacturers. OTOH,IMO, this seems like a perfect solution. I plan to have one of these installed soon.
Old     (dppaneig)      Join Date: Feb 2008       05-07-2008, 8:55 AM Reply
I have only used mine once. I use a drysuit so i really don't need it. The time I did use it, the lake water was really cold and I turned it on my feet when I got out and that was a mistake. I never thought of the stream setting to be used as a squirt gun, maybe I will use it more this year on the girls.
Old     (denverd1)      Join Date: May 2004       05-07-2008, 9:03 AM Reply
for the DIY'ers, rumor is you don't need a pump. engine water pump is enough to put out hot water @ 1000 rpms. I live in texas, so this is really all I would ever need. We take about 10 rides a year that are colder than I would like and we're already back to trunks. so, for <$50 in fittings and hose, it makes sense.
Old     (mobv)      Join Date: Jun 2002       05-07-2008, 10:37 AM Reply
You have to have a pump for the cold water to mix with the hot water from the engine.
The engine has to be running to keep the water hot.
Centurion will not install at the factory because of the above mentioned liability. I understand that CA boats must have a sticker on the back of the boat instructing users that it is unsafe to be on the platform with the engine running.
Old     (deltaboy)      Join Date: Jan 2007       05-07-2008, 2:06 PM Reply
Gregory thats why in CA the shower needs to be up front or away from exhaust. Ours is under the front center bow cushion.
