Old    mike (beef)      Join Date: Jan 2007       05-05-2008, 3:00 PM Reply
We have a small ding on the prop from the trailer being too deep when loading back up. The ding is probably an inch long, and 1/8" dinged (off the original prop line). Will I damage anything if I drive with it this way?? I heard you can burn a prop up, due to the ding creating an air pocket. Is this true? I don't even know how you can burn a prop, but figured I would ask.
I plan on having it machined, but we have a trip coming up, and if I take it in now I'm not sure if we'll get it back in time.
Thanks
Old    rod (rodltg2)      Join Date: Oct 2005       05-05-2008, 3:12 PM Reply
dont run it. buy a new prop and send that one off for repair. then you will have a back up.
Old    K.B.C.            05-05-2008, 3:14 PM Reply
does it vibrate while running?
Old    Ed (elc)      Join Date: Jan 2008       05-05-2008, 5:36 PM Reply
I did something similar earlier this year. Once I took the prop off, I realized I had a couple other smaller dings in it. After reading a bunch of other posts on this topic and talking to a couple friends, I decided it wasn't worth running the prop and messing up the drive shaft.
I am not sure where you are in so cal but if you are near Bronson Propellers in santa ana, they will repair it in a few days and your prop will be as good as it was when you first bought it. They have been around for a long time and do good work.
http://www.boatpropellers.com
Old    Mikeski (mikeski)      Join Date: Aug 2003       05-05-2008, 5:59 PM Reply
When we had $12,000 boats and $300 props we used to straighten them with a mallett and run them. Now that I have a $50k boat and a $350 prop I tend to replace it. A prop is really no more costly than a car tire. Get a new prop, have the old one fixed and carry it as a spare.
All that said, in 20+ years of boating I have yet to see any drivetrain damage caused from a prop with monor damage. 3 out of 4 blades missing, that is a different story.
Old    KEVIN (kko13)      Join Date: Jul 2006       05-05-2008, 7:38 PM Reply
i would have to see it but if its small you will be fine i would have it trued up when you can but i would not let it stop me from going out if it is small. dings are nothing but if it takes one or more of the blades out of plain then you will have a problem.
Old    mike (beef)      Join Date: Jan 2007       05-07-2008, 8:06 AM Reply
Thanks guys, maybe I'll try to run it to the Santa Ana. My dealer takes a while, and charges about $180.
Old    Nacho (denverd1)      Join Date: May 2004       05-07-2008, 8:45 AM Reply
FYI its from your trailer not being deep enough. Build up your bunks and you won't have to worry.
