Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through May 08, 2008
Old    Deez nuts (spencer3840)      Join Date: May 2005       05-05-2008, 3:13 PM Reply
I'm currently running 2 Kinetik 2000 batteries for my stereo system. My question is do I have to run a Kinetik battery for my starting battery? My stereo shop says yes for sure. But this would be only true if I ran my switch on all right? What do you guys do? And if this is true what model should I get for my starter battery? thanks
Old    Anthony (echo_parker)      Join Date: Feb 2008       05-05-2008, 3:33 PM Reply
Buy a Perko switch. I have 4 Kinetik's for my stereo, and 1 battery that came with the boat. I was never told to switch out the boat battery. I don't think it matters, I never had a problem with mine.
Old    Ben Kerran            05-05-2008, 6:02 PM Reply
deez nuts-you have it right. As long as you don't plan on combining them "both" on the perko, you can use any type for starting. Keep in mind to charge separately also
Old    Mikeski (mikeski)      Join Date: Aug 2003       05-05-2008, 6:53 PM Reply
I have 2 Kinetik 2400's for the stereo and a Red Top for starting. It is the same technology, I could parallel all together but I don't. I use a Yandina C150 combiner to connect the stereo bank to the factory charging system. Charging is the only reason anything in the stereo system gets connected to anything in the stock system.
Boat battery systems are very confusing to most installers.
Old    Deez nuts (spencer3840)      Join Date: May 2005       05-06-2008, 12:25 AM Reply
So would a Kinetik starting battery be a good one to go with? Or is their a better choice of starting battery? I never run my switch to all so I'm not concerned getting the same battery.
Old    Brandon (bwillx2)      Join Date: May 2007       05-06-2008, 8:00 AM Reply
Nuts,
I just bought an HC1800 for my starting and have a HC2400 for the system, but I have mine connected to a relay, so when the boat is going they are both connected. It was the best amp hour I could find for the money. The optima's have 55 amp hours for around $140 and the HC1800 has 81 amp hours for $179. I just liked having the same type battery so there would be no questions as to working properly. I'm sure there are better starting batteries out there. I wanted something that would help out with the system a little bit also
Old    Jason Neves (jv210)      Join Date: Feb 2006       05-06-2008, 10:24 AM Reply
Brandon, were are you finding the hc1800's for 179?
Old    Deez nuts (spencer3840)      Join Date: May 2005       05-06-2008, 10:59 AM Reply
how big is the 1800? Meaning whats the measurments?
Old    Brady (pdxWAKE.com) (big_b_21v)      Join Date: Oct 2006       05-06-2008, 12:08 PM Reply
10" x 6.5" x 8.2"
54lbs
AH: 81
Amps: 1900
Yes, I am curious too where you are getting the $179 deal???
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       05-06-2008, 12:59 PM Reply
HERE.
http://www.millionbuy.com/kinkhc1800.html
Old    Brandon (bwillx2)      Join Date: May 2007       05-06-2008, 2:25 PM Reply
You got it Nu bu!!
