Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through May 08, 2008
Old    Danny Farren (face_smash)      Join Date: Aug 2004       05-06-2008, 5:22 AM Reply
Hi there guys i have put loads of goodies on my mastercraft this winter and have realised i need to upgrade the alternator!! (After paddling back the other day!!) I have the LQ9 and according to the owners manual on mastercraft website the alternator is pushing out 51 amps at 2200 RPM and the upgrade is to a 90 amp Alternator at 2200 RPM.
I have added a :
Heater
Shower
4 JL amps
4 wetsound Pro 80s
2 wetsound 10 inch subs
do you think the 90 amp alternator is good enough???????
Old    Brett Yates (polarbill)      Join Date: Jun 2003       05-06-2008, 8:50 AM Reply
Do you keep your boat on the trailer in the garage at night? Do you listen to the stereo loud while just sitting or only while riding? What type of batteries, how many and how are they set up?
Just to give you an idea the formula for calculating how many amps your boat requires to keep the batteries at a full state of charge is:
Watts/volts=amps
Assuming you have 2000 watts in your stereo you would need this amount of watts to keep fully charged.
2000/12=166.66 amps.
This is not entirely accurate because your system is actually going to be 12.6-13 volts I believe so you can drop the required amps. Also that equation is assuming the stereo is drawing the full 2000watts the whole time which it isn't. But then you have to add for the PCM, lights, electronic gauges, heater, shower and anything else that is drawing power from you charging system.
I am guessing that you have a Motorola style aternator since you say it is a 51 amp. That alternator only puts out 35 or so amps at idle. Idle being 2000 rpm. That is idle rpm of the alternator not the engine. Your engine probably idles around 600-700 rpm. With a 3 to 1 pulley ratio you are around 2000 rpm idle at the the alternator. The 90 amp alternator only puts out another 5 amps at idle, but at wakeboarding speed would put out close to that full 90 amps.
If I were you I would make sure I have a 2 battery system with 3 batteries. Make sure you have something to separate your starting and critical systems from your house bank. Makes sure you use all the same types of batteries(gel, agm, lead acid). If you really want to do it right get a starting battery(make sure it has enough CCA to start your boat easily). Then get a couple other deep cycle batteries to run in parralel to have the amps hooked up to. I would also install a battery charger on your boat so you can plug in the boat at the end of the day and trickle charge the house bank to keep charged and not damage the batteries.
Wow I think that is the longest post I have ever made. I do think there are too many people that think you can just add a cheap 150 amp alternator and solve all your problems.
Old    Danny Farren (face_smash)      Join Date: Aug 2004       05-06-2008, 9:00 AM Reply
Wow Brett you da man when it comes to alternators!!!! thank you so much!! I do have a 2 battery set up ad i have checked and i have a 70 amp alternator!! i have foud a company that can rewind the alternator for me to whatever i want!!! do you not think that doing this will solve my problems??? i was thinking about getting a Optima battery also (have 3) just to run the sound system!! what do you think???
Danny
Old    Danny Farren (face_smash)      Join Date: Aug 2004       05-06-2008, 9:02 AM Reply
Oh yea and it was a long message!! ha ha
Old    Brett Yates (polarbill)      Join Date: Jun 2003       05-06-2008, 9:07 AM Reply
Danny, that will probably help if you have the alternator redone. Don't get an optima battery if you have regular lead acid batteries to. Different types of batteries require different voltage and you can fry one battery and not charge up another.
What type of batteries are in your boat and how are they wired?
Old    Danny Farren (face_smash)      Join Date: Aug 2004       05-06-2008, 9:14 AM Reply
they are wired in parallel and they are hang on im just going to have a look!!!
Old    Danny Farren (face_smash)      Join Date: Aug 2004       05-06-2008, 9:17 AM Reply
ok they are a SCHNAPP battery ENGERY GOLD and i believe they are lead acid and are 70 A.H.
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       05-06-2008, 9:28 AM Reply
"SCHNAPP"
Old    Brett Yates (polarbill)      Join Date: Jun 2003       05-06-2008, 9:31 AM Reply
nu bu, don't you mean
"Oh Schnapp" or
"Who got some Schnapp's on the petrol"
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       05-06-2008, 9:34 AM Reply
You're killing me Brett
Old    Danny Farren (face_smash)      Join Date: Aug 2004       05-06-2008, 9:35 AM Reply
WHAT??? Whats wrong with them???? or is it the cool names we give to our stuff over here??? ha ha
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       05-06-2008, 9:42 AM Reply
I'm easily amused Danny..
Old    Danny Farren (face_smash)      Join Date: Aug 2004       05-06-2008, 9:44 AM Reply
ha ha no worries dude me to!!!! but can anybody help me??? because my boat does not last more than 4 - 5 hours before both of my batteries are dead!!!!
HELP
Old    Ken W (kenteck)      Join Date: Jan 2005       05-06-2008, 9:50 AM Reply
brent,
tell steve he needs to be in radio
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       05-06-2008, 9:58 AM Reply
Danny I have 3 JL amps (slash series) on my boat and I run 4 batteries for the stereo, and one for a reserve. You might think about adding some batteries to your setup. Are you charging them completely after every outing? You can't rely on your alternator to recharge them fully.
Old    Brett Yates (polarbill)      Join Date: Jun 2003       05-06-2008, 10:09 AM Reply
Danny, does it die from just sitting and playing the stereo or just running around wakeboarding and stuff? I don't know anything about the Schnapp batteries. What you want to do is have one battery that has a high CCA rating for starting, the pcm, and other critical components. Then get one big or 2 smaller deep cycle batteries with high 20 mp Hour ratings to be the house bank. You want to hook the main power and ground for your stereo/amps to this bank.
Use a product like a Sure Power part# 1314 to separate the banks. This product keeps the banks separate from each other. It also is set up to give priority to the bank of choice. You want the bank with priority to be the starting bank. It only charges that bank till it reaches a certain voltage and then combines the batteries and starts charging the house bank. This is nice because it keeps your critical systems charged so you don't end up dead in the water. This product is cheap and easy to install. Here is a link to the product.
http://www.surepower.com/separator.html
Agree with what nu bu just said.
Old    Danny Farren (face_smash)      Join Date: Aug 2004       05-06-2008, 10:09 AM Reply
I have never had to worry about charging them before adding all this stuff!!! i think i will upgrade the Alternator and add another battery and hope that cures the problem!! i think i will try and push 180 amps on the alternator! I think the sound system is pushing around 1800 watts and then the heater and hot shower also!!!
Old    Danny Farren (face_smash)      Join Date: Aug 2004       05-06-2008, 10:13 AM Reply
No Brett the batteries discharge just from running around the lake i was really careful about playing anything or running the heater and stuff while the boat was not running!!!! it took the whole day but the battery warning signal came on!!!!!
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       05-06-2008, 10:13 AM Reply
Danny you need to charge the batteries at the end of the day, or before you take the boat back out. They aren't getting charged back up with the alternator, and the alternator can't keep up with the current draw of the amps. If I were you I'd add another battery, leave the alternator as is for now, get a good battery charger and be diligent about charging them after every outing. If you do this I doubt you'll have any more problems.
Old    Danny Farren (face_smash)      Join Date: Aug 2004       05-06-2008, 10:17 AM Reply
The only problem with that nu bu is the boat is left in the water quite often and i cant get a power source out to it???
Old    Brett Yates (polarbill)      Join Date: Jun 2003       05-06-2008, 10:21 AM Reply
180 amps out of a small frame alternator is a lot. My guess is the heat that is going to cause will fry that puppy quick. Just a though but if you are running your shower don't have your stereo cranked and the same with the heater. Although I do realize you may have the heater on while you are riding or cruising and that is when you would want the stereo cranked up.
I like nu bu's setup of having 3 or 4 batteries all in parallel to run the stereo.
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       05-06-2008, 10:31 AM Reply
Danny no power does pose a problem then. I'm sure someone on here has a good idea of how to charge your batteries back up without access to a power supply. Maybe the big alternator is going to be your best bet. Balmar makes some HO alternators that put out up to and over 200 amps.
Old    Brett Yates (polarbill)      Join Date: Jun 2003       05-06-2008, 10:34 AM Reply
What about one of the solar panel chargers they use for hydraulic boat lifts? Has anybody ever used one of these? It might not charge fast but at least it is something.
Old    Danny Farren (face_smash)      Join Date: Aug 2004       05-06-2008, 10:36 AM Reply
I think i will up the power of my alternator and add another battery ad hope that, that solves the (annoying) problem!!!
Brett thats a pretty good idea!!!
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       05-06-2008, 10:53 AM Reply
The solar panel is a great idea. Danny maybe you can get an alternative energy credit for doing the solar panel route. .
(Message edited by 05mobiuslsv on May 06, 2008)
Old    Brett Yates (polarbill)      Join Date: Jun 2003       05-06-2008, 10:55 AM Reply
Start with that Danny and monitor it. The problem is low voltage kills lights and electronics in your boat eventually as well as the starter and alternator.
Old    bthom (billthom)      Join Date: Apr 2005       05-06-2008, 11:24 AM Reply
Brett, with that Sure Power separator I assume it is best to work with the stereo wired to the house bank only? I currently have a perko switch and only two batteries but I think I need more power.
With three amps I think I might be pulling too much from my current system. I see the volt meter in the dash jump on bass hits. So I want to add a third battery and maybe some sort of separator. So if I do that I wonder if I should move all amp connections to the two stereo batteries?
I already have a great 3bank charger onboard I hook to the batteries at night on the dock.
Thanks!
Old    Brett Yates (polarbill)      Join Date: Jun 2003       05-06-2008, 1:09 PM Reply
That is correct Bill. You should have all the amps wired just to your house bank. What I tell people about the battery selector switches is did you buy a 50k boat have to lift a cushion and flip a switch. The Sure Power unit is a little over $50 and works better than an isolator and isn't really more expensive.
What kind of batteries do you have Bill?
Old    tom fischer (tomfish)      Join Date: Apr 2003       05-06-2008, 1:14 PM Reply
going to a bigger alternator will help but still even at a 100-120 amp (which is about the most you can get from your small frame alternator w/o spending a grand) alternator it will not charge your batteries up. Alternators will usually at most maintain a charge and charge a little maybe with NOTHING running but the motor. I would clearly get 3 batteries at least with your 4 amp setup. Checkout Lifline batteries, or other sealed agm or gel batteriers. 2 in paralell and then a third separated with a perko or something for starting only or a reserve to get you home. If you are running a big system you MUST use a battery charger to charge them back up after running them down no matter how big your alternator is it will not charge them back up to 100% like an overnite trickle at 10+amps. If you store it in the water you may be forced to take them out at night and bring them to shore for an overnite charge or get a small honda quiet generator and get 15-20 amp speed charger and let that thing run while you get all loaded up or at least for a couple of hours some how. Lose the Scnepps for sure. Good luck
Old    bthom (billthom)      Join Date: Apr 2005       05-06-2008, 2:12 PM Reply
Brett, totally hear you on the switch flipping…I assume that can then just take the place of the perko?
I have the stock two battery option from Supra…I know they are interstates but I’m not sure what kind – one is a cranking and the other a deep cycle. Do I need to make sure I add the same type of battery to the system as the other two….or do I NEED to replace them all?? I thought I would just go buy another similar type deep cycle and install parallel to the current deep cycle.
My charger can handle different types, but I think they all need to be the same: http://www.promariner.com/productFeature.php?ProductNum=42021. I just installed it next to the batteries, since I have on-dock power I just plug it in after coming in. But I can’t leave it plugged in overnight since it says it needs ventilation and I don’t want to leave the boat uncovered all night…I don’t know how important the ventilation is but I figure better safe than sorry…
Thanks for the help…I owe you one once the weather gets nice.
Old    Sam (wake1823)      Join Date: Dec 2005       05-06-2008, 2:38 PM Reply
Your alternator is NOT a battery charger! It should not be used like one. Using it that way is the best way to blow your alt.
The 90 amp alt is a pretty strong alt and can takle a beating. This 120-135 amps alts floating around ( at least the cheap ones..less than $200 are mostly junk, using cheap parts)
Old    Brett Yates (polarbill)      Join Date: Jun 2003       05-06-2008, 3:01 PM Reply
I agree with Sam.
Bill, you do want to make sure they are all lead acid if that is the way you wanna go. I would not just add a new battery to the house bank side though. Adding a new battery to an old one in the same bank can shorten the life of the new one. I would add 2 new batteries wired in parallel to the house side. My company does very good with Deka batteries and they have all the options of lead acid, gel or agm batteries. If you can get me the part number of the starting battery I can see if I can get something that is compatible in Deka at a good price.
I also carry the Sure Power product. I forgot to mention the 1314 is rated at 100 amps so it should be fine with a stock alternator.
