Old    Blake (x10wakerider)      Join Date: Jan 2004       05-02-2008, 10:46 AM Reply
Is there a web site or previous post that explains the installation in a step by step process?
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       05-02-2008, 11:01 AM Reply
like for the wiring ?
Old    Blake (x10wakerider)      Join Date: Jan 2004       05-02-2008, 11:26 AM Reply
Yes, and the best way to feed the wire down the tower.
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       05-02-2008, 11:33 AM Reply
I bought a tower wiring harness from bulletlines.com (http://www.bulletlines.com/servlet/the-14/Wakeboard-Boat-Tower-Speaker/Detail) and drilled 2 holes in the tower ran it up one of the front tower legs with a long piece of metal wire nd I wired up 3 lights and 2 speakers with it . . . If you want I'll post some pics of the install
(Message edited by lovin_the_wake on May 02, 2008)
Old    Jason (loonytik)      Join Date: Apr 2008       05-02-2008, 11:46 AM Reply
Use a fish tape, drill some holes in your tower and get lucky hitting the hole.
Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       05-02-2008, 11:55 AM Reply
I drilled the holes then used fishing line and a nut tied to the end of the line. Next I used the magnet on the back of my sub to drag it through the tower. It only took about 3 min.
Old    Bill K (bill_airjunky)      Join Date: Apr 2002       05-02-2008, 12:01 PM Reply
Another way is to drill the two holes & push a piece of sting in the top hole, then suck it out the lower hole with a shop vac. No luck involved at all.
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       05-02-2008, 12:44 PM Reply
the magnet idea is pretty neat
Old    Hate N Pain (hatepain)      Join Date: Aug 2006       05-02-2008, 1:23 PM Reply
The shop vac sounds pretty nice and easy too. I've also heard you can use some string and compressed air and just blow it through then fish out the string at the bottom.
Old    George Aslinger (mobv)      Join Date: Jun 2002       05-02-2008, 1:38 PM Reply
The shop vac really works, by far the easiest way to get the fishing line through and then pull the wire.
Old    MOX (uofamox)      Join Date: Feb 2007       05-03-2008, 2:22 PM Reply
The string/shop vac trick usually works unless there is a lot of oil inside your tower. I ended using a fish tape and worked great.
Old    Greg Bodor (gti2lo)      Join Date: Nov 2005       05-03-2008, 3:24 PM Reply
coat hangers work well too and are usually easy to get.
Old    Clint (ttuclint)      Join Date: Sep 2003       05-03-2008, 9:05 PM Reply
take a piece of string and put some tape on the end so the shop vac will have something easier to suck thru.
If you use any other method you are just making things hard on yourself.
