Old    Cliff (ord27)      Join Date: Oct 2005       04-30-2008, 6:20 PM Reply
this is my off season contribution to the boat this year
a dual bank battery charger
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       04-30-2008, 6:43 PM Reply
Nice work Cliff... That's clean.
Old    Cliff (ord27)      Join Date: Oct 2005       04-30-2008, 6:44 PM Reply
thanks nu bu
figure I will plug it often to keep those babies in good shape
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       04-30-2008, 6:52 PM Reply
Use it after every outing and you'll never have battery issues. What kind of batteries are you running. I stuck 5 optimas along that wall you put your onboard charger.
Old    Cliff (ord27)      Join Date: Oct 2005       04-30-2008, 7:06 PM Reply
I've got 2 blue tops
just run 2 amps and only 2 tower speakers so I didn't feel the need for more batteries
Old    Patrick Fort (pfort)      Join Date: Mar 2007       05-01-2008, 9:37 AM Reply
Looks good, I plan to install my battery chargers this weekend.
Old    Kelly (weskel)      Join Date: Jan 2007       05-01-2008, 11:59 AM Reply
what battery charger did you use?
Weskel
Old    Cliff (ord27)      Join Date: Oct 2005       05-01-2008, 11:28 PM Reply
hey Kelly. it's a Promite 5/5 dual bank
trickle charges both at the same time
cuts off and back on on it's own so you can keep it hooked up thru the winter if you want
Old    Erik (kinger)      Join Date: Jun 2007       05-02-2008, 7:25 AM Reply
Sorry, this might be dumb, but how does a battery charger work? I usually hook the battery up to a trickle charger the night before I go out, is this ok? how will a battery charger help?
Thanks
Old    Cliff (ord27)      Join Date: Oct 2005       05-02-2008, 7:35 AM Reply
Erik
mine is the same thing, just mounted in the boat and able to charge 2 batteries at the same time
I just have to stretch the cord to the boat...instead of lugging a charger into the boat every time
Old    Erik (kinger)      Join Date: Jun 2007       05-02-2008, 7:53 AM Reply
thanks
Old    Kelly (weskel)      Join Date: Jan 2007       05-02-2008, 9:55 AM Reply
Thanks for the info, that is not a bad price, I have to replace my two batteries this year, neither will take a full charge.
I will also install this charger, maybe my batteries will last longer than a couple seasons.
Kelly
Old    Les D. (ldebbold)      Join Date: Jun 2006       05-02-2008, 1:03 PM Reply
I'm having a problem with my duel blue top optima batteries. They were installed by a good stereo shop last fall along with rewiring the battery selector switch which was apparently not hooked up correctly by another dealer shop. I turned them off for the winter and then put the switch on "all" and hooked up my charger to just one of them a couple of weeks ago before we took the boat out. Long story short, I think only one of the batteries took any charge, and the other battery doesn't seem to be charging even when I run the boat with the switch on all. What is wrong and how do I fix it? Thanks
Old    Cliff (ord27)      Join Date: Oct 2005       05-02-2008, 3:14 PM Reply
I'm not sure Les, but it is my understanding that you cannot charge both batteries at the same time using a conventional charger
you need a dual bank charger
I have seen lots of posts on here from guys in the industry
I'm sure one will respond soon
