Old    Ryan Nobles (fordmxracer)      Join Date: Dec 2007       04-25-2008, 4:07 AM Reply
Where can I find the best deal on a PP wakeboard pro?
Thanks Ryan
Old    Jay T. (wakebrdjay)      Join Date: Apr 2008       04-25-2008, 4:58 AM Reply
check with Ian Brown at onlyinboards.comm he'll hook you up
Old    Matt S. (1irondragon)      Join Date: Apr 2008       04-27-2008, 9:14 AM Reply
I second Jay T. You will not find a better deal then through Ian. Customer service was great, and I got mine in 3 days after ordering. I just finished my install last night and might be going out today to give it a try!
Old    Matthew Bird (ldr)      Join Date: Nov 2002       04-27-2008, 3:17 PM Reply
buy the PP cruise upgrade kit then buy the remaining pieces directly from PP. It comes out to just under $800.
Old    Rich (rich_g)      Join Date: May 2003       04-27-2008, 5:07 PM Reply
Matthew, could you be a little more specific. If you're starting out with nothing what exactly do you need to order? what are the remaining pieces?
Old    Matthew Bird (ldr)      Join Date: Nov 2002       04-27-2008, 5:34 PM Reply
PerfectPass Pro =
servo motor
master module
paddle wheel
rpm cable
servo motor cable
power cable
When you buy the cruise upgrade kit (the kit needed to upgrade someone who already has PP cruise to PP pro)
($550) you get
master module
paddle wheel
probably a new power cable
what you need to complete the system would be
servo motor (most expensive)
servo motor cable
rpm cable
maybe power cable
PP will be able to give you exact pricing.
I found this out when searching for my system and i found that PP is a couple hundred cheaper buying piece meal than buying a complete system.
Old    Rich (rich_g)      Join Date: May 2003       04-27-2008, 7:09 PM Reply
thanks, I will check that out
Old    Brandon Kee (trickyboarder08)      Join Date: Jul 2005       05-06-2008, 9:12 AM Reply
Here is what I got back from perfect pass on the things you would need to complete the system.
Your prices are as follows:
Servo Motor with Cable - $224 USD
RPM Sensor - $40 USD
Power Cable (for Master Module) - $20 USD
Servo Power Cable - 13 Ft. or 23 Ft. - $35 USD (not sure which power cable
you want so included both prices).
Shipping charges would apply on any/all of the above.
so therefore it would be 319 for all of that stuff plus 549 for the upgrade.
So that would be $868 and that is before shipping.
Still cheaper to go that route though.
