Old    Ronia (ladythump)      Join Date: Jul 2004       04-24-2008, 8:25 AM Reply
i need to replace my trailer jack. assuming the new one comes with instructions, but juse in case, has anyone ever done this before? i have no clue how to get the original off.
thanks.
Old    KStateAlumni (bbeach)      Join Date: Jul 2002       04-24-2008, 8:28 AM Reply
Mine required snap ring pliers to get the rotating mount off. FYI...
Old    Ronia (ladythump)      Join Date: Jul 2004       04-24-2008, 8:32 AM Reply
I was just reading some old threads and i think mine may be welded to the trailer. i need to double check what piece i need. anyone else?
Old    Doug H (doug2)      Join Date: Jan 2004       04-24-2008, 8:35 AM Reply
The two replacement jacks I've installed have four bolts that go through a plate welded to the tongue.
Fairly straightforward. But I have seen some like KState mentioned where the swivel hardware is integrated into the tongue.
Does it look like this?
http://www.skidim.com/prodinfo.asp?number=5800496
(on edit)I forgot I had this place bookmarked. You might be able to replace part of the jack if that would be easier.
http://www.easternmarine.com/em_store/jacks/
(Message edited by doug2 on April 24, 2008)
Old    Mike (bladeaustin)      Join Date: Feb 2008       04-24-2008, 8:54 AM Reply
I just did this and KSTAE is correct; it did require snap ring or c-ring pliers.
Old    Ronia (ladythump)      Join Date: Jul 2004       04-24-2008, 8:59 AM Reply
its a boatmate trailer if that helps. i'm going to call boatmate later today.
Old    George Aslinger (mobv)      Join Date: Jun 2002       04-24-2008, 9:52 AM Reply
I replaced one on a boatmate trailer last year. 4 bolts that held it on.
Old    Jman (jmanolinsky)      Join Date: Dec 2005       04-24-2008, 10:43 AM Reply
My 2000 model boatmate trailer required the C-clip removal.
Jman
