Old     (badzuki)      Join Date: Sep 2001       03-09-2003, 8:52 AM Reply
Would there be a noticeable differences in a 10 to 12" solo baric sub? I can't decide if the price and size is worth it. My other question is will a 12" solo fit in front of the drivers feet(where the original sub is) more so will I be able to fit the appropriate enclosure behind it? Has any X-star owners put in a solo? How does it sound?
Old    Charley Carvalho (wakeeater)      Join Date: May 2002       03-09-2003, 10:42 AM Reply
i personaly think tens thump harder then 12s and 152 but opinons are like butts everyones got one
Old    xtigeman            03-09-2003, 12:40 PM Reply
Ten may be tighter, but twelve generally go deeper and play louder.
Old    Jeff Hill (hillbilly)      Join Date: Aug 2002       03-09-2003, 1:40 PM Reply
just saw a JL 10w7 anybody have any comment on that speaker? It sounded good in the store and the guy said it blew away 2 of the kicker 12's.Is he just trying to push product???
Old    Charley Carvalho (wakeeater)      Join Date: May 2002       03-09-2003, 3:19 PM Reply
nope i compared that sub to some kicker 12s and a 15 the 12s and 15 were deeper sounding but the tens that i tried out thumped hard. the other 10 was some kind of polk audio one
Old    Darren Yearsley (ralph)      Join Date: Apr 2002       03-09-2003, 3:25 PM Reply
In my car I've got a 12inch in a 10 inch box, it's a nice compromise, hits a bit harder but still gives the ambient deep bass rumble. It also takes up heaps less space which is a bonus.
Old    tabiggs            03-09-2003, 5:22 PM Reply
If you have the power, the solo baric cant touch the JL W7's
Old    xtigeman            03-09-2003, 7:09 PM Reply
W7s are killer, but require a lot of power and a big box. W7s are also SQ as opposed to SPL, but they are loud.
Two other subs to consider that have just as good or better SQ are the ID MAX and the Eclipse Titanium. Both require less power to hit X-Max and require smaller boxes which is a good thing in a boat.
I get the same dbs out of both an ID MAX and the Eclipse at 450 watts as I do out of a W7 at 900 watts. The ID MAx may even play the deepest of the three and the Eclipse seems the most accurate on real fast double bass bang your head ranchy metal.
Old    Sean M (magic)      Join Date: Mar 2002       03-09-2003, 10:28 PM Reply
I have an Eclipse 12 Ti in my boat. I'm feeding it 600watts rms from it's own amp. The sub just takes it and sounds good. It's in about .9ft^3 after displacement.
Don't forget about the Adrie Brahmas! They like small boxes too, but require a lot power like the JL W7s.
(Message edited by magic on March 09, 2003)
Old    TY-one-on (typhoon)      Join Date: Jul 2001       03-10-2003, 6:53 AM Reply
Two good 10's or 1 solid 12. if you are tight on space as most are go with one 12
Old     (badzuki)      Join Date: Sep 2001       03-10-2003, 8:35 AM Reply
I see that the 12" ID Max requires 1.30 -1.52 cu.ft. sealed. Would there be enough room for that size of enclosure if I mount the sub in the panel in front of the drivers feet? How many watts are you running to each of your subs Doug?
Old    TY-one-on (typhoon)      Join Date: Jul 2001       03-10-2003, 8:53 AM Reply
If you have the money, get the adire brahma...
Look also at the crystal cmp and the mobile audio mass. another to look at is the edesignaudio.com
all are very nice
Old     (badzuki)      Join Date: Sep 2001       03-10-2003, 9:03 AM Reply
No I don't have the money. That is why the solo was a choice. But I may spring for a ID Max or JL.
Old    TY-one-on (typhoon)      Join Date: Jul 2001       03-10-2003, 9:07 AM Reply
if you are a little tight on loot get the edesign k series sub. will play as loud if not louder than the solo and will outplay the jlw3 (which I own also). awesome and optimized to work in a tiny enclosure.
www.edesignaudio.com/
Old    hlboatsnboards            03-10-2003, 11:56 AM Reply
I run 2 10"w6v2 in my boat. Last year i had 2 15"w3's and the 10's blow them out of the water (no pun intended). The 15's produced a lower sound, cost less, but these 10's are incredible!!!!! High priced too...ouch!!!
B
Old    BeeTL (ofwc)      Join Date: Sep 2002       03-10-2003, 3:14 PM Reply
Based on an old "subwoofer" post, I just ordered an Elemental Designs sub and an AudioFormz enclosure.
I can't wait to get the system installed and hear how it sounds!
Old    TY-one-on (typhoon)      Join Date: Jul 2001       03-10-2003, 3:20 PM Reply
The e-subs are killer. Look at the baskets alone on those things let alone the surrounds.
Old    Bob (bob)      Join Date: Feb 2001       03-10-2003, 3:36 PM Reply
anyone have any feedback on the Infinity subs, im looking at the kappa (not the perfects though they are a bit pricey). Ive got a 10" sony ES im feeding it 300 rms in a sealed enclosure and want to replace it with a 12" in a ported enclosure?? I thought a ported enclosure will produce the most spl, why do i hear so much about sealed boxes then, everyone that short on space?
Im wanting to make the box out of ply and cover the inside and outside with glass but im not sure what size ply to go with. Im not wanting to make a 1" thick 1.75 cu ft enclosure since it will weigh a ton. Any ideas what size ply i can get away with?
Old    TY-one-on (typhoon)      Join Date: Jul 2001       03-10-2003, 3:38 PM Reply
The infinity subs do not do a bad job at all. The perfects are very nice. the reference do a good job. For that price I would look at the e-design.
Old    xtigeman            03-10-2003, 3:58 PM Reply
Badzuki:
900 to a 12W7
450 to ID MAX
450 to 12 inch Eclipse Titanium
Elemental Designs are great too. Brahma is definitely one of the best, but it seems like most people using them to their full extent are running 1,500 to 2,000 watts to them.
Old    Shawn (shawnmdarnell)      Join Date: Feb 2003       03-10-2003, 4:10 PM Reply
Badzuki
i am running nine max 12's, eight in the back with 2 1001-1 xtant amps (little over 2400 watts) and a 500-1 power up front. this subs hammer! these subs are hand built and can handle a lot. if you can get your hands on one, get it, you won't be sorry.
Old    matt moss (mossy44)      Join Date: Oct 2001       03-10-2003, 4:20 PM Reply
doug, you gonna be riding at all this summer? where ya been?
Old    Jeff Hill (hillbilly)      Join Date: Aug 2002       03-10-2003, 6:14 PM Reply
if you run a sealed box you get crisper bass correct?And if you port the box it is "boomier" and louder.Is that correct or have i been misinformed.
Old    beercity            03-10-2003, 6:19 PM Reply
Ty have you seen the Adire Tumult? That is gonna be a KILLER sub.
Old     (badzuki)      Join Date: Sep 2001       03-10-2003, 7:28 PM Reply
Doug-
Would I have enough room for a 12 inch sub and enclosure if I mount the sub in the panel in front of the drivers feet?
I like that ID Max. So many choices, so little money.
Old    Bob (bob)      Join Date: Feb 2001       03-10-2003, 7:33 PM Reply
isnt louder what you want in a boat??
Old    Shawn (shawnmdarnell)      Join Date: Feb 2003       03-10-2003, 7:33 PM Reply
badzuki,
i have a id max enclosure in the panel in front of the drivers feet with a fosgate power 500-1 pushing it. i recomend it highly
Old     (badzuki)      Join Date: Sep 2001       03-10-2003, 7:52 PM Reply
500 watts going to it? I think that sounds like the most sound for the price. Do you have the 2Ohm? A dual 4 Ohm, can you tie them together? I guess is there any perks to one or the other?
Old    Shawn (shawnmdarnell)      Join Date: Feb 2003       03-10-2003, 8:05 PM Reply
yes, i got 500 watts going to that sub at a dual 4 ohm. in the back i got 2400 watts going to eight ID Max 12's.
Old     (badzuki)      Join Date: Sep 2001       03-11-2003, 4:26 AM Reply
Do you run 500w to each of the leads on a dual cone or can you tie them together or what? What flexibility does it give you(benefit)?
Old    CMC X Stars (02wakesettervlx)      Join Date: Jun 2001       03-11-2003, 6:11 AM Reply
Badzuki,
I have a 10" L5 Solobaric in my boat, and it pounds. The clear advantage to a Solo is space requirements. I have a heater, and I still have the box mounted by my feet. I can also help you out with the Solo, since it sounds as though money is an issue. E-mail me in private at wakesettervlx@hotmail.com and I will let you know how I can help. Didn't you hear my boat at Boot Camp last year?
Old    TY-one-on (typhoon)      Join Date: Jul 2001       03-11-2003, 6:31 AM Reply
BC BOY,
I will look. Anything adire does is awesome though so I want to see it.
I actually did a vented enclosure on an orion hcca 12 with a 900 watt amp running it. Sounds great.
Old    xtigeman            03-11-2003, 1:53 PM Reply
Matt:
What's going on. I will be riding this summer and hopefully soon. Maybe we can hook up. My schedule was a bit hectic. We are working the details out on a $ 20 + million dollar settlement so I may kick it in a different gear and not work quiet as hard this summer.
Badzuki:
I think the driver's feet is the best placement for sound. You may be able to find a good deal on an ID Max on the net. Check out uscarsudio.com and woofersetc.com. They used to have pretty good prices.
Old     (badzuki)      Join Date: Sep 2001       03-11-2003, 7:42 PM Reply
Thanks Doug, my X-star is still in storage so I can't measure what size of enclosure will fit.
