Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2008
Old    Michael Israel (izzy)      Join Date: Apr 2007       04-07-2008, 12:40 PM Reply
I used my new Uber Pump(First time I ever used any ballast system)...It filled fine but when I went to drain water (lots) was coming out the side of the pump. Is this normal? If not what can I do to fix it? Thanks for the help!
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       04-07-2008, 12:51 PM Reply
OK I had this exact same problem with mine and all I did to fix it was use RTV silicone around the parts that goes into the sac and around the part that "seals" the pump
Old    Josh B (joshugan)      Join Date: Apr 2005       04-07-2008, 12:56 PM Reply
I had this same exact problem with every one of the many warrantied pumps I got from them. Simply, it's a horrible design that quickly breaks. See if you can get it warrantied and then get a different brand.
Old    Michael Israel (izzy)      Join Date: Apr 2007       04-07-2008, 1:10 PM Reply
I was thinking about the RTV idea, I figured it would work but was not sure if it would mess it up. Thank you!
Old    Kevin Hoye (wakebrdr38)      Join Date: Sep 2006       04-07-2008, 1:59 PM Reply
it comes with an o ring you have to put on the inside
Old    Michael Israel (izzy)      Join Date: Apr 2007       04-07-2008, 2:08 PM Reply
The O ring is there...it was just a really loose fit.
Old    Dan Duer (libertylake)      Join Date: Jul 2007       04-07-2008, 3:10 PM Reply
Yep, Silicone worked for me. I actually called Straight Line and silicone was their suggested solution. Hasn't leaked since.
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       04-07-2008, 3:14 PM Reply
Dan, I'm pretty sure you're the one who told me a while back to use the silicone
Old    Dan Duer (libertylake)      Join Date: Jul 2007       04-07-2008, 4:00 PM Reply
Montgomery...glad it worked then..
Old    Matt (loudsubz)      Join Date: Aug 2001       04-07-2008, 4:00 PM Reply
can you buy just the adapter for it?
I have been looking all over for it.
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       04-07-2008, 5:08 PM Reply
Dan, It definitely worked and thanks :-)
Matt, You might check buywake.com
