Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2008
Old    Clubmyke (clubmyke)      Join Date: Aug 2004       04-06-2008, 10:33 AM Reply
what is the easiest/efficent way to bleed trailer brakes without making a mess ?
i was looking at a vacuum pumps and there are different ones- any suggestions ?
Old    Kevin (pri3st)      Join Date: Aug 2007       04-06-2008, 10:42 AM Reply
http://www.speedbleeder.com/
Old    Clubmyke (clubmyke)      Join Date: Aug 2004       04-06-2008, 10:57 AM Reply
wow !!! way cool !! many thanks !1
Old    Scott Legge (w00taz)      Join Date: Jun 2007       04-06-2008, 1:39 PM Reply
I do it the old way I use a mityvac hand suction pump. Works great.
Old    Aaron Ware (99_slaunch)      Join Date: Oct 2005       04-06-2008, 1:58 PM Reply
Crack the bleeders open and let gravity take over. Just don't let the master cylinder get dry.
Old    alan plotz (alanp)      Join Date: Apr 2001       04-06-2008, 8:15 PM Reply
i second the mityvac works great.
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       04-06-2008, 8:42 PM Reply
Aaron, you can't be serious...
Old    Aaron Ware (99_slaunch)      Join Date: Oct 2005       04-07-2008, 8:40 AM Reply
Why not? It will push the air out yes or no? I have seen it done many times and work just fine.
Old    Scott Legge (w00taz)      Join Date: Jun 2007       04-07-2008, 4:20 PM Reply
yea as long as the master cyl is higher than the outlets and there arent any "high spots" where air can settle in the lines. Basically brake lines have to be run like sewage. Gravity bleeding works well too im just impatient.
Old    Peter_C (peter_c)      Join Date: Sep 2001       04-07-2008, 6:18 PM Reply
You still need to use a giant pry bar and work it just like a car, in that you pump the master up, then open the bleeders. I didn't look at the link above, but a pressure bleeder is the way to go.
