I am in the process of installing a 2-outlet heater in my boat and I am almost finished. I was running the heater hose that runs from the engine ('97 SS, V-drive) to the heater core, which is located under the dash. The only place I can run the hose is under the gunnel along the starboard side of the boat. The problem I am having is that I have a bunch of wire running in that same spot and I didn't know if the heater hose would burn that wiring. The hose is touching the wiring how I have it run right now. Is this ok? If not, then where should I run the hose? Thanks for any help!
