Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2008
Old    Flight007 (poser007)      Join Date: Nov 2004       04-02-2008, 7:45 PM Reply
SO beofre I stored my boat for the winter I checked to see if all the stereo equipment was working. I pulled it out of storage and today got in it and was checking stuff out. I turned on the sound and it only played theough the subs? I have 6 interior speakers and 2 subs and 2 tower speakers. Did I touch a button on the unit or would this most likely be a bad connection some where?
Old    Mike G (mike_gilbert)      Join Date: Sep 2004       04-02-2008, 7:47 PM Reply
Similar problem happened to me except my rear right side speakers dont work the rest do, I havent had time to check the speakers but im thinking it could be my amp
Old    Cal (phenom_1819)      Join Date: Jan 2008       04-02-2008, 8:57 PM Reply
Check all fuses for your amps, and be sure that all power, ground, and REMOTE wiring is intact... I would assume two am two amps are out since your boat and tower speakers aren't turning on, my first guess would be that the remote wire came loose at one connection that knocked both amps out...
Old    KEVIN (kko13)      Join Date: Jul 2006       04-02-2008, 9:00 PM Reply
agree it sounds like you lost an amp.
Old    Flight007 (poser007)      Join Date: Nov 2004       04-02-2008, 10:37 PM Reply
Thanks I will check that tomorrow after work
