Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2008
Old    Carter (junker_lf)      Join Date: Sep 2007       03-27-2008, 7:21 PM Reply
Has anyone ever used Rain X on their hull to cut down on the water spots from building up?
Old    Rich (dohboy)      Join Date: Aug 2007       03-27-2008, 7:30 PM Reply
That would be expensive. A good coat of wax costs less. I use rainx on my goggles for riding and it stinks. I couldn't imagine my whole garage smelling like solvent. That would be funny if it worked though.
Old    Carter (junker_lf)      Join Date: Sep 2007       03-27-2008, 8:54 PM Reply
Maybe ill just stick to the waxing method haha. thanks.
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       03-27-2008, 9:14 PM Reply
Wipe it down with the babe's water spot product and it won't get them, also making sure you have a good coat of wax will help alot also.
Old    Kevin (deltaboy)      Join Date: Jan 2007       03-27-2008, 11:22 PM Reply
I'm with Nu Bu. I have a mostly black boat and have used Babes since day one and never had an issue w/ water spots. Get it by the gallon.
Rain X reaks. Just apply to the wind shield and then go into the garage the next morning....instant high. I couldn't imagine how bad it would be if you did the entire hull.
Old    brandon christian (brandfish)      Join Date: Mar 2008       03-28-2008, 3:55 AM Reply
hey i heard if you Rain X your whole boat you get better hole shots and a couple extra knots!
Old    mike (beef)      Join Date: Jan 2007       03-28-2008, 9:28 AM Reply
I use it in my shower?!?!?!?!
Old    Patrick Fort (pfort)      Join Date: Mar 2007       03-28-2008, 9:39 AM Reply
Try using Rejex
http://www.corrosionx.com/rejex.html
This stuff works awesome. Follow the directions and you will not be disappointed. It also works great on wheels to keep off the brake dust.
Old    Carter (junker_lf)      Join Date: Sep 2007       03-28-2008, 10:33 AM Reply
Where do you guys get Babes from ive never heard of it..
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       03-28-2008, 11:41 AM Reply
Here is the stuff. Use this if you have water spots, to keep from getting them use the Boat Brite.
http://www.babesboats.com/prodSpotSolver.php
Old    Andrew Carnacchi (07launch22ssv)      Join Date: Feb 2007       03-28-2008, 6:53 PM Reply
if you read a bottle of rainX i believe it says not to get it on a painted surface which i would imagine makes it not good for gel as well.....
