Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 24, 2008
Old    Supreme Rob (supreme_rob)      Join Date: Sep 2005       03-23-2008, 9:21 AM Reply
I have an 05' boat and trailer that is stored outside,the tires tread wise are in good shape but I noticed some sun damage on a couple of the tires ie: spider cracks on the side wall. Should I worry about this and just replace the tires or is this just cosmetic. Also the trailer sits all winter and although I keep the tires aired up, is it just part of ownership to replace trailer tires every few years when your in a posistion of outside storage.
Old    George Bugg (gbugg19)      Join Date: Oct 2007       03-23-2008, 9:42 AM Reply
Sounds like dry rot. If you trailer often or long distances I would consider new tires. or at least keep a good spare and necessary tools to change it.
Old    Hugh Jas (malibupilot)      Join Date: Nov 2005       03-23-2008, 11:12 AM Reply
G E T N E W T I R E S.
Unless you only drive a mile or two to launch, get new ones. I was in the same situation and one-after-another, they all blew out.
Old    rick ator (mkperceptions)      Join Date: Jan 2007       03-23-2008, 11:17 AM Reply
Get new tires. Also to preserve your new set try using tire covers to keep the sun off of them. Atleast i the winter or when storing for a long time.
Old     (1boarder_kevin)      Join Date: Mar 2007       03-23-2008, 12:23 PM Reply
I agree completely. Unless you never go over 20 mph, get new tires. If you blow one, you will be replacing a 500 fender and may even wreck.
trailer tires are very different than car tires as the sidewalls have a lot of force applied to them. I personally will never run a trailer tire anywhere close to wearing out the tread.
I personally like goodyear marathons
Old    lakeski (lakeski)      Join Date: Dec 2006       03-23-2008, 12:44 PM Reply
Check your tire stems, too. They can rot and cause a blow out, as well.
Old    Andy Graham (ottog1979)      Join Date: Apr 2007       03-23-2008, 10:04 PM Reply
Get new tires. Mine were 5 years old, plenty tread left. On our trip to Powell last summer from San Diego, we threw a tread off. It wrapped around the trailer fender and bent it like it was tin foil. Now, in addition to a $450 set of new trailer tires I have probably as much in bodywork & paint to get the trailer fender fixed. No damage to the boat, but the bill could have been more.
