Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 24, 2008
Old    Fill er up (fill_er_up)      Join Date: May 2006       03-21-2008, 3:35 PM Reply
I use the fat sac quick connects and was considering cementing the piece that screws into the sac to make it solid. Any ideas to get a solid connection without making it permanent? Also, when I got them there was a coating of grease(?) which keeps the o-rings flexible. What kind of grease is that?
Old    greg (lav)      Join Date: Jun 2007       03-21-2008, 3:49 PM Reply
Multi purpose pvc cement. I called fly high and that is what they recommened it will release with hair dryer heat. as far as the grease on o-ring no ideas but if you call them they have excellent customer service
Old    Nacho (denverd1)      Join Date: May 2004       03-21-2008, 4:04 PM Reply
Old    Newty (newty)      Join Date: May 2005       03-21-2008, 6:19 PM Reply
Typically vaseline is used on o-rings for that type of environment.
Old    Scott Dearduff (clearlakescott)      Join Date: Apr 2007       03-21-2008, 6:27 PM Reply
go to a pool store and get some o-ring lube it works great
Old    TigeMike (chpthril)      Join Date: Oct 2007       03-21-2008, 6:29 PM Reply
Vaseline, being petroleum based, will cause the rubber to swell, use pure silicone paste
Old    Leo Lasecki (malibuboarder75)      Join Date: Jan 2004       03-21-2008, 6:31 PM Reply
I used marine 5200 by 3m
Old    William (kana12)      Join Date: Jan 2008       03-21-2008, 6:56 PM Reply
the name of this thread sounds kinky !!!
Old    Brandon (bp420)      Join Date: Mar 2008       03-21-2008, 8:12 PM Reply
yeah o-ring lube from home depot will work on the o-ring. Put a few wraps of teflon tape around the threads and then screw it in. You'll be able to unscrew it by hand but it wont come undone and will be completely water tight.
Old    Ewing (johnsvt)      Join Date: Dec 2006       03-21-2008, 9:01 PM Reply
I was told to use rubber cement and o-ring lube.
Old    Scott Legge (w00taz)      Join Date: Jun 2007       03-22-2008, 12:55 AM Reply
giggidy giggidy
