Old     (malibuboarder75)      Join Date: Jan 2004       03-18-2008, 5:22 PM Reply
I have a 95w appliance that I want to run on the boat. Will a 100w car inverter work. Is it safe?
Old     (chpthril)      Join Date: Oct 2007       03-18-2008, 5:25 PM Reply
Blender?
Old     (malibuboarder75)      Join Date: Jan 2004       03-18-2008, 5:37 PM Reply
Actually a pump.
Old     (chpthril)      Join Date: Oct 2007       03-18-2008, 5:45 PM Reply
Details!!!
I've used a small one to power my laptop, had no problems.
Does it say how many Amps DC it draws. If the 100w inverter has a breaker that would trip in case of over load, then give it a shot.
Old     (malibuboarder75)      Join Date: Jan 2004       03-18-2008, 5:48 PM Reply
That is what I dont understand. The pump says 95W and 1.33 Amps. If P=IV, then this is wrong. Because at 110V, the power should equal 146 Watts. Everywhere states that this pump is under 95 watts. As far as power inverters, they are rated on watts not amps. So wouldn't a 95w amp run on a 100w continuous inverter?
Old     (ord27)      Join Date: Oct 2005       03-18-2008, 5:53 PM Reply
I run a 500w inverter hooked to a breaker so things won't blow fuses
if you haven't purchased one yet....just go bigger
woo hoo
check out the chart on the optima battery site
cant find the link....I have it bookmarked at home
I will post it later
it pretty much tells you how big of a inverter to use based on appliance used
Old     (fletch_tx)      Join Date: Aug 2003       03-18-2008, 6:00 PM Reply
is there any danger of running that large of an inverter on your boat? would a larger alternator be a requirement?
Old     (ord27)      Join Date: Oct 2005       03-18-2008, 6:04 PM Reply
my stereo guy didnt think so
I power a 4 hp vacuum/blower/inflator
blows up a 2 man tube in no time!
i just forget to turn it on, so it will "charge"
takes a little bit to "charge"
Old     (ord27)      Join Date: Oct 2005       03-18-2008, 6:08 PM Reply
can't remember which one I have....it might be larger than 500
I will check that also....later
http://www.nextag.com/cobra-power-inverter/search-html
Old     (malibuboarder75)      Join Date: Jan 2004       03-18-2008, 6:16 PM Reply
How many watts does the blower consume?
Old     (ord27)      Join Date: Oct 2005       03-18-2008, 7:27 PM Reply
I cant remember Leo
I will have to post when I get home
but that'll be midnight central time.....
Old     (ord27)      Join Date: Oct 2005       03-18-2008, 7:33 PM Reply
http://www.bartswatersports.com/catalog/Tubes_and_Towables/InflatorDeflators/MagicAir_Commercial_InflatorDeflator/index.asp
http://www.metrovacworld.com/Shopping/product.asp?catalog_name=metrovac&category_name=&p roduct_id=MagicAirDeluxe
found that one
I am actually thinking about going with the dida-2 instead....for the boat
the dida-4 is a beast
Old     (ord27)      Join Date: Oct 2005       03-18-2008, 7:40 PM Reply
ah
found the other site also
Leo, I hope this helps
http://www.1st-optima-batteries.com/optima_inverter_applications.asp
Old     (peter_c)      Join Date: Sep 2001       03-18-2008, 8:19 PM Reply
Leo, that is not enough margin. There will be a giant spike on start up, for any electric motor. Go bigger. In fact get one rated at over 1000 watts so you can run a blender. I paid $75 for one from Costco that is 1750 watts.
Old     (ord27)      Join Date: Oct 2005       03-18-2008, 10:28 PM Reply
what I have is a 1500 watt inverter
the Cobra cpi 1550
Old     (dhcomp)      Join Date: Jun 2003       03-18-2008, 11:45 PM Reply
do teh costco one. I'd get way higher than 100watt if you are running a 95 watt applicance.
Give some room for variance...and other thigns you may want to run.
