Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 24, 2008
Old    Patrick (2manytoys)      Join Date: May 2007       03-17-2008, 8:53 AM Reply
I assume it would be ok.. but wanted the Gods of WW approval... Right now I am running the stock 13.5x17 on my 04 X2 .. looking for a backup and found a 14x20 .. Would there be any problems? FWIW.. I just run with stock ballast... mix of wakeboarding..kneeboard and pullin the boys on the tube... I assume I would lose some bottom end but wanted everyones input..
Old     (1boarder_kevin)      Join Date: Mar 2007       03-17-2008, 9:12 AM Reply
That would be a bad prop in my oppion unless you have a 8.1, which I doubt. Then again it depends on what you feel acceptible with. Most people with that boat and the rtp1 or mcx feel the 13.5x17 is to high of a pitch and go the other way. Some did run a 13.5 x 19 though and could give you more concrete info.
Old    Patrick (2manytoys)      Join Date: May 2007       03-17-2008, 9:21 AM Reply
Boat has the mcx.. it would only be a backup because where I live it would be impossible to find a prop if I damaged it while out on the lake.. I can get it for 100$.. I know its not the perfect choice but was wondering if it would get me by in a bind.
Old    Brandon Kee (trickyboarder08)      Join Date: Jul 2005       03-17-2008, 9:23 AM Reply
Technically you can run that prop.
BUT I don't see yo being happy with it.
Old    Nacho (denverd1)      Join Date: May 2004       03-17-2008, 9:37 AM Reply
it would get you thru a weekend or an afternoon if you had to.
Old    Patrick (2manytoys)      Join Date: May 2007       03-17-2008, 3:56 PM Reply
With the higher pitch it would lose bottom end and holeshot... but gain top mph right?
Old     (1boarder_kevin)      Join Date: Mar 2007       03-17-2008, 4:06 PM Reply
if the motor can spin it
Old    VLX Envy (cavlxenvy)      Join Date: Aug 2007       03-17-2008, 11:35 PM Reply
Yeah a 20 pitch is way too high.
Old    Patrick (2manytoys)      Join Date: May 2007       03-18-2008, 8:55 AM Reply
Thanks guys.... I will just keep looking... kinda hard to find a MC prop because they are splined. much less a good deal on one
Old    Nacho (denverd1)      Join Date: May 2004       03-18-2008, 9:33 AM Reply
there's an acme 537 floating around somewhere. it was cheap if i remember. good backup
Old    John Gardner (roverjohn)      Join Date: Dec 2007       03-18-2008, 9:48 AM Reply
for $100 you could always buy it and have it repitched. You should still be in it for less then $200 unless repitching costs a lot more than it used to.
Old    Nacho (denverd1)      Join Date: May 2004       03-18-2008, 10:00 AM Reply
that a lot of pitch to take out, but Its an option. i think you could find a better prop for the money.
Old    Nacho (denverd1)      Join Date: May 2004       03-18-2008, 10:07 AM Reply
http://www.wakeworld.com/MB/Discus/messages/3183/558953.html?1205851622
Old    Patrick (2manytoys)      Join Date: May 2007       03-18-2008, 6:18 PM Reply
that one wouldn't be splined would it..
