Old    wakeman456            02-27-2003, 11:32 AM Reply
How can I prevent someone from stealing my tower Boss speakers? I was going to weld them but Boss advice me not to do that (can cause problems with speakers).
What should I do? they are too expensive to leave them out in the open all night, they are way too easy to steal.
Any ideas???
Old    Phaeton (phaeton)      Join Date: Feb 2002       02-27-2003, 11:47 AM Reply
You can try to find special bolts to replace the allen heads. Or Epoxy the allen heads so someone will have to chisle the epoxy out before they can loosen the bolts.
Be sure and make copy's of all your reciets and take them to you insurance agent.
Travis Farber
Wake Me Products
www.Wake-Me.com
Old    norcal_99            02-27-2003, 12:06 PM Reply
Drill the mounting holes large enough to fit a sliding hitch lock and use that to mount them.
Or take the speakers off while it's stored outside.
Old    wakeman456            02-27-2003, 12:20 PM Reply
Has anyone drill on the mount before?
Old    S Dub (sdub)      Join Date: Jan 2003       02-27-2003, 12:26 PM Reply
I was thinking the same thing. Drill a 3/8" hole in the mounting arm, and use a cable lock to the tower. There just aint enough room on 530's arm to do that.
Rene- sliding hitch lock? can you explain what that is. Thanx.
Old    GD (greatdane)      Join Date: Feb 2001       02-27-2003, 12:31 PM Reply
Ryan of rynogear was going to look into a lock-on solution for his mounts. The hitch lock is a great idea. Ideally also the hardware holding the brackets on the tower would be hidden when the speaker is locked in place. This way the speakers are easy on/off and lockable.
Old    norcal_99            02-27-2003, 12:32 PM Reply
Look at this web site
http://www.auto-extra.com/hitch_lock.htm
Old    GD (greatdane)      Join Date: Feb 2001       02-27-2003, 12:42 PM Reply
Something like this...
http://www.mooretruckaccessories.com/mooretruckaccessories/Receiver_Pins_and_Locks.html
Old    Paul (gherk)      Join Date: Aug 2001       02-27-2003, 1:30 PM Reply
I hate to be the one to point this out, but if someone really wanted your speakers, they could just take the tower with the speakers attached and worry about getting the speakers off later. Maybe something to consider if you have a quick release or fold down tower.
Old    Sandy Vandebult (sandbag)      Join Date: May 2002       02-27-2003, 1:50 PM Reply
yeah, I take the speakers off every time.
Besides theft, my speakers spend more time
on a nice clean shelf in the garage than
they do hangin' from the tower outside.
I only mount them when I want to use them.
I've never seen anything that was [Florida]
sunproof!
Old    wakeman456            02-27-2003, 2:15 PM Reply
does any one have a picture of a tower been locked with a sliding hitch lock?
I am not sure how to lock with a hitch-lock my B-69 speakers.
Old    andy zarlengo (colorider)      Join Date: Jun 2001       02-27-2003, 3:12 PM Reply
A cable lock is too easy to cut. Filling the allen bold heads with JB weld is the best idea. It would take a power tool to get it out.
Old    S Dub (sdub)      Join Date: Jan 2003       02-27-2003, 4:07 PM Reply
Yeah, with JB wled problem solved, but also new problem. You need to take them off sometimes. If they want them, they will get them. But, slowing them down they might just go on the next boat.
Old    GD (greatdane)      Join Date: Feb 2001       02-27-2003, 4:23 PM Reply
Many thefts are thefts of convenience. Some teen walks by, sees the speakers and says "wow, those look nice and easy to take".
A simple lock works wonders for this.
Old    Bob (bob)      Join Date: Feb 2001       02-27-2003, 7:00 PM Reply
I do what sandy does, pull em down after the day, mine have two knobs on each speaker and they are down.
Old    nohalfboats            02-27-2003, 7:19 PM Reply
boat alarm or at least stickers and a flashing light.
Old    andy zarlengo (colorider)      Join Date: Jun 2001       02-27-2003, 8:32 PM Reply
To get the JB weld out of the allen hole, I just used a dremel tool with a steel brush attachment. Cleaned out each hole in about 1 min.
Old    Stewart McLean (gizel)      Join Date: Dec 2002       02-28-2003, 6:45 AM Reply
Here is a site that has an assortment of different types of bolts. I use a one way machine screw. you have to buy a special tool ( About $15 ) to remove them and they are flat so you can't just use a pair of pliers or something else to remove them. It still gives you the ability to take them down off the tower when you need to but prevents them from being stolen. Its also a lot easier than drilling out the mounts to try and put a cable lock or slide lock on them.http://www.hudsonfasteners.com/security.htm
Old    wakeman456            02-28-2003, 11:24 AM Reply
On the speaker mount I'm going to use security screws instead of allen.....the problem is the screw you see on the pic, next to the red electricity plug. That is the one holding the speaker.
What is JB weld used for? is that permanent?
Any ideas?
By the way have u seen a Searay with tower? lol...the boat is on a warehouse not much light in it.
Old    S Dub (sdub)      Join Date: Jan 2003       02-28-2003, 12:47 PM Reply
Stewart, thanks for that link. Those will work.
Old    wakeman456            03-01-2003, 10:43 AM Reply
Any more ideas guys???
