Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 24, 2008
Old     (sulmaxwell)      Join Date: Dec 2003       03-14-2008, 11:52 AM Reply
not talking about that weirdo that stands on the corner...ha ha..sorry Friday... couldn't resist
How often should one change their transmission fluid in the boat as well as what kind of replacement fluid to use, as well....directions on HOW to change it???
Old     (denverd1)      Join Date: May 2004       03-14-2008, 11:57 AM Reply
most use ATF (auto tranny fluid)
the hand pumps or drill pumps are the easiest way to get it out.
replace with same volume you pump out.
Old     (chpthril)      Join Date: Oct 2007       03-14-2008, 12:01 PM Reply
I change my V-drive and transmission fluid once a season while winterizing.
My Borg-warner uses Dexron automatic transmission fluid.
Old     (peachman)      Join Date: May 2004       03-14-2008, 12:07 PM Reply
I generally change mine every 50 hours.
Normal ATF unless the manufacturer recommends something else.
What I do to replace mine:
Items required, bucket, 3 empty quart bottles, hand pump, lot's of rags & large towel.
Put the towel down on the floor, I put the empty quart bottles in the bucket and pump out the old fluid into the empty bottles, replace with new ATF what you took out, test levels and you are good to go. I use the bucket to catch any fluids that might escape. Keeps the carpet clean.
JT
Old     (denverd1)      Join Date: May 2004       03-14-2008, 12:10 PM Reply
oh yea, once a season or every 50 hrs.
Old     (chaser)      Join Date: Sep 2006       03-14-2008, 12:54 PM Reply
Check your manual. I beleive mine says every 100 hours, at least once a season? I use 15w40 motor oil as that is what is recommended.
Old     (denverd1)      Join Date: May 2004       03-14-2008, 1:12 PM Reply
the MC transmission and owners manual can differ. 6 one way 1/2 dozen the other:
http://www.tmcowners.com/teamtalk/showthread.php?t=21225
Old     (mastercraft1995)      Join Date: Nov 2002       03-14-2008, 1:42 PM Reply
Some use SAE30, ATF or 15-40. Change it every year or 100 hours.
Old     (wakesetter101)      Join Date: Oct 2005       03-14-2008, 7:55 PM Reply
THis works the best.
http://www.overtons.com/modperl/product/details.cgi?i=24770&pdesc=Marina_Pro_Oil_Changer&c name=Oil-Changers-/-Filters&aID=24A&merchID=1009&r=view
Check level on stick first, then just add what ever it takes to make it the same.
Old     (liquidmx)      Join Date: Jun 2005       03-14-2008, 9:27 PM Reply
I change mine every 50 hrs with the oil. It may be more often than necessary but with running a lot of ballast I figure that it couldn't hurt.
