Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 24, 2008
Old    marty bess (martyslc)      Join Date: Jul 2007       03-13-2008, 5:03 PM Reply
I have a 2005 Mobius XLV and in the book it say under the yearly maintenance chart to clean the transmission oil strainer screen.
Any Ideas where the heck would I look for that?
-Marty
Old    Troy (liveoz)      Join Date: May 2002       03-13-2008, 7:34 PM Reply
If you follow the hose from your impellar (water pump), you should find it. On a Malibu it is not far from the pump, not sure if it is similar on the Mobius. You are looking for a metal cylinder that is slightly larger on one side than the other, should be a hose going in and coming out. I take mine off and clean it every couple of weeks to remove weeds, takes 30 seconds.
(Message edited by liveoz on March 13, 2008)
Old    Greg McNeill (greg2)      Join Date: May 2002       03-13-2008, 8:45 PM Reply
Is he talking about the transmission cooler as pictured above or the strainer for the transmission fluid?
Old    Troy (liveoz)      Join Date: May 2002       03-13-2008, 11:17 PM Reply
My bad, that may NOT be the oil strainer screen you were looking for. I was referring to the screen in the oil cooler element. The transmission Oil filter and screen would be on your transmission itself. That would not be a 30 second job unfortunately.
Old    marty bess (martyslc)      Join Date: Jul 2007       03-14-2008, 7:29 AM Reply
I'm wondering if that's what they are referring too?
Here's what I'm looking at in the manual.
-MartyUpload
