Old     (fossilfuelburner)      Join Date: Feb 2008       03-20-2008, 8:29 AM Reply
I finished an automatic ballast installation on my boat and posted the project on wakeboarder.com if anyone is interested.
http://forums.wakeboarder.com/viewtopic.php?t=74688
Old     (chadgreg)      Join Date: Feb 2008       03-20-2008, 9:22 AM Reply
I am in the process of doing this right now. In your write up you said you had a total cost of $397??
I have a 3 bag system and the bags alone are $330, I am just at about $850 total. I am starting from scratch and I have included all costs from bags, fittings, pumps, hose, clamps etc....
HOW DID YOU BUILD IT SO CHEAP?
Old     (fossilfuelburner)      Join Date: Feb 2008       03-20-2008, 10:20 AM Reply
The bags are the most expensive parts. My install only has one ballast in the ski locker so I'd say you're doing good at $850.
(Message edited by fossilfuelburner on March 20, 2008)
Old     (rich_g)      Join Date: May 2003       03-20-2008, 10:36 AM Reply
nice writeup. I have a question about the check valve. You said you used a "spring" check valve. I don't have firsthand knowledge, but most of the info I have seen says that aerator pumps do not put out much pressure; therefore most people go with a "swing" check valve, which works with a rubber flap in the valve.
If your systems works that's great, but if the pump has trouble pushing water thru the cv, you could always switch to a swing cv for not too much $$.
