Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through February 24, 2008
Old    Brett Wyatt (bwyatt74)      Join Date: Feb 2008       02-20-2008, 7:24 AM Reply
i took out the stock sacs for the back and put in two 750 lb bags and i also have a 700 lb bag in the front... does anyone have any good comments to make the perfect wakeboard wake (speed, trim, weight, etc.) thankks
Old    Jon Allen (jon_a)      Join Date: Feb 2003       02-20-2008, 12:33 PM Reply
You are going to need to throw a lot more weight up front if you only have 700 in the front. Supras really like weight in the middle and front with the way the hull is shaped. If you fill the 750s in the back all the way up you are going to need to add at least another 700 in the front on top of the 700 already there. Run about 23 mph with the wakeplate at 50%.
Old    Bill Montanye (bill)      Join Date: Feb 2001       02-20-2008, 3:06 PM Reply
yea i second that you will need the 1000-1100 pound sack for under the bow or use one of your old sacks from the back in the bow on top of the seats..
Old    Patrick Fort (pfort)      Join Date: Mar 2007       02-21-2008, 3:18 PM Reply
I use to run the 750's full in the back, the 1100 in the bow, and threw one of the stock 400's on the front cushions. Normally rode around 22-23 and played with the wakeplate to each riders liking. If you don't have the wake prop it is a must with the heavy ballast.
