Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through February 24, 2008
Old    atom_ant            02-13-2008, 4:36 PM Reply
Just seeing if anyone has some "use this" or "don't use this" advice for patching a fat sac. The hole is about 1/4 inch in diam. Thanks in advance
Old    Brandon Kee (trickyboarder08)      Join Date: Jul 2005       02-13-2008, 4:53 PM Reply
Don't they come with a patch kit?
Old    Jos (jtnz)      Join Date: Sep 2007       02-13-2008, 5:29 PM Reply
A water bed patch kit should work, or a bicycle tyre patch. Scuff up the surface and the back of the patch a little bit with some sandpaper and make sure it is dry before you glue the patch on.
(Message edited by Jtnz on February 13, 2008)
Old    Brian Kaufman (madison_boarder)      Join Date: Apr 2006       02-14-2008, 5:44 PM Reply
Austin,
I went to a pool supply store and asked for a pool patch (use their glue too, it actually works even BETTER underwater, so wetness isn't an issue)... works PERFECTLY.
Old    atom_ant            02-14-2008, 10:01 PM Reply
Thanks Brian, sounds good to me.
Brandon, you're probably right, but mine are ancient and if they did come with one it's gone now.
Old    LimoTinted (ridininmd)      Join Date: Jun 2006       02-15-2008, 6:49 AM Reply
I used a patch I had laying around from a tube and Amazing Goop on mine. It worked really well.
Old    Jeremy Byrom (wakerider111)      Join Date: Jul 2006       02-15-2008, 12:49 PM Reply
Shoe Goo is pretty good stuff to create a patch in of itself(if the hole isn't massive). 'course an extra piece of rubber helps too ;)
