Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 21, 2008
Old     (bob_l)      Join Date: Jul 2006       02-13-2008, 2:27 PM Reply
I waxed the boat before I put it in covered storage for the winter and do not assume the wax has has broken down so was not planning on waxing when I took it out (start of the season wax). Do you guys usually wax again before you start using it?
Old     (buzz_grande)      Join Date: Mar 2004       02-13-2008, 3:03 PM Reply
Not a bad idea. Sure could not hurt.
Old     (bmartin)      Join Date: Jan 2007       02-13-2008, 3:49 PM Reply
I have three teenage boys - so the boat gets waxed at the beginning of the season, in the middle of the season, and at the end of the season. I mean they have to earn their pulls some how.
If the boat is completely enclosed, I would suspect very little wax would break down, but like Buzz said, it certainly won't hurt.
Old     (alanp)      Join Date: Apr 2001       02-13-2008, 5:13 PM Reply
if you have covered storage i wouldnt wax. uncovered wax to preserve the gel coat.
Old     (mastercraft1995)      Join Date: Nov 2002       02-14-2008, 2:49 PM Reply
I wax it 4 or 5 times before it touches the water for the first time every year. By waxing it all the time it helps with the water spot removal
Old    swass            02-14-2008, 2:56 PM Reply
That's a waste of time. Waxing five times doesn't mean you have five coats of wax - it means you have one coat of wax that you've applied five times. The solvents in the wet wax (the coat you're applying) "re-liquifies" the dry wax, so you're doing five times the work to get one coat of wax.
(Message edited by swass on February 14, 2008)
Old     (bill)      Join Date: Feb 2001       02-14-2008, 3:13 PM Reply
what kind of wax do you all suggest and in what form??
buff or by hand??
Old     (seminolepride991)      Join Date: Sep 2007       02-14-2008, 3:52 PM Reply
BY HANDD!!!!!!!!!! takes a little more elbow grease but buffers can be veryy mean to the color on the boat
Old    swass            02-15-2008, 8:02 AM Reply
The kind of wax you choose is 100% personal preference. Some like natural Carnuba; some prefer synthetic. The argument over which is better is similar to a Ford vs. Chevy debate: pretty pointless.
Hand wax vs. machine: Again - personal preference. Keep in mind that there's a big difference between a buffer and a polisher. Lots of people have buffers; few have polishers. You can't do much damage with a buffer unless you're using a really aggressive polishing compound and you're holding the buffer in one spot and applying a lot of pressure for a long time. (If you're using a buffer, I'm assuming you're not using a cutting pad.) I don't use a buffer around the decals, but I was ridiculed for that one. On the other hand, if you use a polisher - you better know what you're doing. The risk of damage can be much greater.
This is a great place to learn all about buffers, polishers, pads, etc.
http://www.autogeek.net/
BTW, my comment about more than one coat of wax assumes you're using a natural wax. I don't know if the same holds true for a synthetic.
Old    swass            02-15-2008, 8:04 AM Reply
I have a feeling some will take exception to the "pointless" remark. There are pros and cons to each, but it still boils down to preference, IMO.
