X-star wake is soooo damn hard to get, and to add to that im goofy, it took around 2800 lbs of sacs to get it big but it wasnt very clean. But since your on the port side you in luck. I talked to my buddy darren and trevor at my dealer, and their advice was to not use the stock rear ballast, its not place right. And make sure that you weight the whole port side! not just the rear, i had a 750 and a 250 in the front i took on some water, but its all good. Just make sure to evenly distribute the weight and you should be okay.
