Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 21, 2008
Old    mike asch (mikea)      Join Date: Mar 2005       01-31-2008, 7:19 PM Reply
We are thinking about building at "the lake" and there is a hill that has me concerned.
( it looks much steeper going down)
Often, without towing, I will shift to 1st gear and coast making it most of the way down without touching the breaks.
the details:
F150 with 4wd
the trailer tandom axle with breaks
the road is crushed stone.
Does anyone have any suggestions or advice?
Old    Chris (rio_sanger)      Join Date: Apr 2007       01-31-2008, 7:27 PM Reply
Do you have a transfer case (low range)?
My truck in low range will pull almost anything up almost anything, and going back down I
barely need to use the brakes.
(Message edited by rio_sanger on January 31, 2008)
Old    AnT (regalado1)      Join Date: Dec 2005       01-31-2008, 7:30 PM Reply
Get a Diesel.
Old    Jason Callen (westsidarider)      Join Date: Feb 2003       01-31-2008, 7:36 PM Reply
just try it. either you make it or you dont. haha. ive done traveled some roads much more hairy than that with a econoline 250 2 wheel drive
Old    Bill K (bill_airjunky)      Join Date: Apr 2002       01-31-2008, 9:47 PM Reply
I don't think it'll be a problem. Might take 4wd to do it going up. And 1st gear or low range coming down.
Old    Greg Bodor (gti2lo)      Join Date: Nov 2005       01-31-2008, 9:49 PM Reply
That hill isn't bad at all.. I dont suspect you will have any issues at all.
Old    mike asch (mikea)      Join Date: Mar 2005       01-31-2008, 11:04 PM Reply
I do plan on using 4wd low to go up and down.
I was more conerned about starting to skid and loosing control. once that starts, things could get ugly real quick.
Old    Nacho (denverd1)      Join Date: May 2004       01-31-2008, 11:34 PM Reply
from that pic, depends on whats behind you! if you got plenty of room, then it won't a big deal.
(Message edited by denverd1 on January 31, 2008)
Old    rick ator (mkperceptions)      Join Date: Jan 2007       02-01-2008, 12:41 AM Reply
my rav4 could tow a boat up that any day LOL I am assuming the pics dont do it justice?
Old    Jonny (wakeboardlasvegas)      Join Date: Mar 2007       02-01-2008, 12:48 AM Reply
if that is your biggest challenge is that mole hill..by all means BUILD IT, and they will come!
Old    SEAN DEAN (05elitevc4)      Join Date: Jan 2008       02-01-2008, 7:44 AM Reply
Looks ok to me..maybe the pic doesnt show the entire climb. But by the looks of it I am pretty sure my 1/2 ton Z71 could go up and down pulling my Centurion without having to use 4 wheel at all. But I know pics sometimes look really different in person. Best of luck. If you are going down and start to slide dont try and bull dog it! Let off the brake a little and ride it out till you get to more of a flat spot.
Old    Jason (azpowerhouse)      Join Date: Jul 2007       02-01-2008, 11:11 PM Reply
Well what are the alternatives!?! GIVE IT A TRY!!
Old    mike asch (mikea)      Join Date: Mar 2005       02-02-2008, 4:06 AM Reply
The picture does not really show how steep the hill is, and the very steep droppoff on the right of the road.
Once I am down the hill it will be all good.
the boat ramp/dock and the barn will be down low.
I did not know if someone on here had any tricks to make it down a steep grade, like dropping the air in the tires to 20 psi or adjusting the brakes on the trailer.
I am just nervous bout doing this the first time.
Old    Brit Rider (brit_rider)      Join Date: May 2004       02-02-2008, 6:19 AM Reply
Seems like you are really over worrying about this. In the UK we tow with much smaller cars and engines - I wouldn't think twice about going up there so long as you know the road and have surveyed the risks (sounds like you have).
Don't sweat it.. I get the feeling this is coming down to your confidence more than the vehicles ability - maybe you should try and find someone locally who has some experience of towing and seek a little guidance?
Old    Bill Sloan (bill_sloan)      Join Date: Nov 2007       02-02-2008, 8:24 AM Reply
Try it first with someone else's boat.
Old    Art (rallyart)      Join Date: Nov 2006       02-02-2008, 8:58 AM Reply
Mike, going down the hill the surge brakes are going to be on some and that will slow the trailer. With a 4wd in low range you won't have to use any brakes on the truck. You'll be going so slow, if you wnat that there is no worry about losing control.
When you are on gravel you get more braking affect if the wheels lock up so don't worry if they do. The added surface area of the gravel piling up gives you increased surface area and that's why the brakes work better. ABS on gravel can be really scary but that can't be on if you are in 4wd. If a gravel road feels scary with ABS in won't be nearly as bad without it.
I don't know if that helps. Usually lowering tire pressure won't matter on gravel.
Old    PM (jetskiprosx)      Join Date: Aug 2004       02-02-2008, 9:04 AM Reply
That hill doesn't look bad at all, my parents drive way is steeper than that and they don't have any problem backing our boat up it.
Old    Nick B (iridelow1998)      Join Date: Jun 2006       02-02-2008, 9:37 AM Reply
Just take it slow so you stay in control. No need to drop any air pressure or anything if you take it slow. You're probably worrying too much over nothing.
Old    Stephen Higgins (srh00z)      Join Date: Jun 2003       02-02-2008, 10:04 AM Reply
You mention a drop off as the gravel road meets the main road, is your trailer going to make that drop off, or is the prop guard going to scrape? I would be inclined to pull the unloaded trailer down the drop off if it is drastic enough to cause a problem.
Old    Drew Danielo (ollies_drew)      Join Date: Jan 2008       02-02-2008, 10:29 AM Reply
You should be fine going down. Don't let your truck gain tomuch speed to where you have to apply the brake sfast. In my travels we have done things like this and worse on gravel. Just lightly keep pressure on the brakes so you never get to where you have to lock them up. Other than that Giver H*LL.
Old    Mike B (mlb75)      Join Date: Aug 2007       02-02-2008, 9:11 PM Reply
If your that concerned you could also consider a brake controller so that you could manually add more trailer brakes slowing the decent while retaining steerage.
Old    Newty (newty)      Join Date: May 2005       02-02-2008, 10:55 PM Reply
I would definitely make sure your trailer breaks are adjusted up properly. Other than that just take it slow. Good trailer breaks will really help.
