Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 21, 2008
Old     (moomba55)      Join Date: Jan 2008       01-31-2008, 7:32 AM Reply
when getting in the boat using the swim platform black residue from the surface of the platform gets all over interior. What might I do to fix the problem?
Old     (dizzyg)      Join Date: May 2005       01-31-2008, 7:41 AM Reply
wash the boat more often. change your oil more often if it is from the exhaust
Old     (mcook77)      Join Date: Feb 2004       01-31-2008, 8:45 AM Reply
Neal - you need to replace the platform surface. Contact Skiers Choice and inform them of what is happening, they will send you the replacement material for free. I had the same issue on my old boat.
You can search the forums here and there are steps to replacing it.
Old     (moomba55)      Join Date: Jan 2008       01-31-2008, 9:25 AM Reply
Michael- thanks for the help.
Old     (nauty)      Join Date: Feb 2004       01-31-2008, 9:38 AM Reply
Neal,
I did as Michael suggested last year. Skier's Choice was great about sending me out some new material ASAP. However, after a month or so the new material started tracking black residue as well. The issue is that UV rays are breaking down the material which causes it to come off on your feet. The material is sprayed with a UV inhibitor on the surface during manufacturing. However, much like sun screen, the UV inhibitor dissipates after a period of time allowing the material to break down.
I replaced material on my platform a second time, but this time I used Hydroturf which has a UV inhibitor blended in the actual material as opposed to being sprayed on top. So far I have had zero residue tracking. Unless Skier's Choice now has a new material that won't break down I would suggest going a different route (Hydroturf or Seadek).
Old     (billthom)      Join Date: Apr 2005       01-31-2008, 9:44 AM Reply
I did the replacement material from Skier's Choice last year. Same as Richard the relief was only temporary. About a month later it started all over again.
Old     (denverd1)      Join Date: May 2004       01-31-2008, 9:45 AM Reply
rip it up and gator grip it.
Old     (moomba55)      Join Date: Jan 2008       02-01-2008, 5:20 AM Reply
I appreciate all the advice. Does anyone know if there is a place in the DFW area that sells any of these products. Hydroturf-Seadek-GatorGrip?
Old     (chpthril)      Join Date: Oct 2007       02-01-2008, 6:14 AM Reply
Order of the internet. I'm redoing mine with GG when it warms up.
www.wakejunky.com
Old     (nauty)      Join Date: Feb 2004       02-01-2008, 6:47 AM Reply
http://www.hydroturf.com/
Old     (05elitevc4)      Join Date: Jan 2008       02-01-2008, 6:50 AM Reply
You could always get a teak one...never have had a problem with mine. And it looks great too!
Old     (zacharoo)      Join Date: Nov 2005       02-01-2008, 7:46 AM Reply
I second the teak deck. With just a little bi-yearly minor maintance you could have this......
Old     (nauty)      Join Date: Feb 2004       02-01-2008, 8:15 AM Reply
I considered switching to teak when I was dealing with my residue issue, but spending $75 on Hydroturf was a whole lot cheaper than $400 + for a new teak platfrom.
Old     (05elitevc4)      Join Date: Jan 2008       02-01-2008, 8:22 AM Reply
I just oil mine and keep it out of the sun when not in use. What other maintenace do you do to your step aquaholic?
Old     (zacharoo)      Join Date: Nov 2005       02-01-2008, 8:37 AM Reply
In the past I to oil but that lead to looking weather. So I now sand and recoat at the end of the season.
This is what it use look like with just teak oil
Now I do this...
Old     (moomba55)      Join Date: Jan 2008       02-01-2008, 8:39 AM Reply
the teak looks really nice but im not looking to spend to extra cash on it. probably going to use the gator grip
Old     (05elitevc4)      Join Date: Jan 2008       02-01-2008, 11:30 AM Reply
So what do you put on it? Does it seal the wood or can it still "breath"??? Mine drys out and gets scuffed up like yours too from all the boards beating it up. But I oil it every time and whenever I head out it looks like your after pictures. I heard that you dont want to seal them up.
Old     (sidwayz)      Join Date: Jan 2008       02-01-2008, 2:31 PM Reply
I used to treat the platform of my XLV with 303, never had a problem with it.
Old     (zacharoo)      Join Date: Nov 2005       02-01-2008, 3:00 PM Reply
It breaths, the teak is not sealed. I found this stuff on the web at www.allguardproducts.com
Its really amazing stuff. The deal with sealers is that the moisture in the wood comes to the surface when the wood gets hot. If the pours are sealed the moisture will bubble and blister the sealer. This stuff breathes and has a UV block. I used this stuff mid season and we too slide over the edge of the platform and it looks pretty much the same as when I apply it.
Old     (05elitevc4)      Join Date: Jan 2008       02-01-2008, 3:50 PM Reply
Good deal thanks for the advise, much appreciated.
Old     (moomba55)      Join Date: Jan 2008       02-18-2008, 1:07 PM Reply
Gator Grip!
Old     (moomba55)      Join Date: Jan 2008       02-18-2008, 1:13 PM Reply
cant figure out how to upload a pic but thanks for all the help.
(Message edited by moomba55 on February 18, 2008)
Old     (flyspec14)      Join Date: Apr 2005       02-18-2008, 1:21 PM Reply
I'll second both Gator Grip and HydroTurf...
