Rich, I've been looking at high def cams for a while trying to figure out what will suit my needs best, and I've run across a lot of your posts, which are always great. If you don't mind, I have a couple of questions for you. 1. could you give me a quick breakdown of your post processing and editing process, as far as what formats, frame rates, etc. you use to get the best performance for wakeboard/fast motion footage? 2. If HDV format is the problem as far as fast motion footage is concerned, does this mean that even a more expensive high def. camera will have the same problems? What improvements, video quality wise, will a more expensive camera give you in comparison to a hv20 type camera?
