Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 21, 2008
Old     (mox369)      Join Date: Jan 2008       01-27-2008, 10:11 PM Reply
Hey guys i have a closed bow 20 foot Sea Ray with a 165 HP I/O and want to wakeboard behind it....is my horsepower sufficent to add a ballast system?? If not, what can i do to get a better wake? any help would be appreciated
Old     (rallyart)      Join Date: Nov 2006       01-27-2008, 11:22 PM Reply
Here's my opinion for you, other's may vary.
In order you need:
A hydrofoil on the leg. I used the Stingray brand.
A lower pitch prop. Maybe two inches less pitch than stock. I liked the 4 blade Vensura but lots like the High 5
A non stretch line.
Bow ballast. In the ski locker is great.
Then add a pylon or tower or more ballast, if you want.
I had an 18' with a 170 hp. Mercruiser 4 cyl for a lot of years.
Old     (lovin_the_wake)      Join Date: Jul 2007       01-28-2008, 6:47 AM Reply
I haven't re-propped my boat yet but they say the difference is like night and day also put most of the weight up front or in the walkway I had a 19" Fourwinns i/o w/ 175hp and ran around 750lbs with 400lbs in the bow and 350 in the walkway and the wake was pretty damn good
(Message edited by lovin_the_wake on January 28, 2008)
Old     (lovin_the_wake)      Join Date: Jul 2007       01-28-2008, 6:52 AM Reply
and actually I have a 350lb locker sac that I don't need if you're interested
Old     (mox369)      Join Date: Jan 2008       01-28-2008, 7:40 AM Reply
yea i am interested....how much do you want for it? email me details if you want.... jonathan@jackpothouses.com
Old     (mox369)      Join Date: Jan 2008       02-01-2008, 3:27 PM Reply
should all my weight be in the bow then?? and how much would you recommend??
Old     (slowjet)      Join Date: Aug 2007       02-01-2008, 11:06 PM Reply
I've got a 1990 Sea Ray 17' with the 130 hp motor. Using the 19 pitch prop we had two 400 lbs fat sacs and usually two people in the boat and a tower. Before I put the foil on it took a little longer to plane, but it pulled fine. Speed holds reasonably well, usually within 2 mph. We had a sac in the bow and one back by the motor. Not a bad wake for an I/O.
Old     (mikea)      Join Date: Mar 2005       02-02-2008, 8:07 AM Reply
re prop it and ride the heck out of it.
don't worry about fixing it up to much (open bow topic).
My first boat was a 16' (closed bow) with a 90 hp outboard.
I had a blast with that boat.
(sometime I think I had more fun with that boat than the one I have now...no radio, no ballast, no money etc..)
Old     (bill_airjunky)      Join Date: Apr 2002       02-02-2008, 12:13 PM Reply
My first boat was the same SeaRay Brandon has. I had a hydrofoil on the leg, a Waylon tripod extended pylon, and about 500 lbs of ballast in the rear & bow. It did OK for us at the time & we used the hell out of it for like 3 yrs.
