Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 21, 2008
Old    Darin Gritters (darinmg)      Join Date: Jul 2006       01-27-2008, 3:02 PM Reply
Has anyone tried removing either of these products from the top deck of their boat? I really want to add something before someone falls putting a board away. I have heard that once it touches, it is there to stay.
Old    Matt (flyspec14)      Join Date: Apr 2005       01-28-2008, 2:23 PM Reply
Alot of scraping and thinner will get it off, it just sucks. Also depends what material it is and how it was put on. If it was pressure-sensitive (peel & stick) you will have better luck. If it was old hydroturf and they used contact cement you will never get it "clean". Although I've put new Hydroturf on top of cleaned and scraped contact cement with good results.
Old    Bill K (bill_airjunky)      Join Date: Apr 2002       01-28-2008, 3:04 PM Reply
I've always had pretty good luck using a heat gun or hair dryer. Once the adhesive heats up, it releases a bit & can be peeled up a lot easier.
Even letting the boat sit out in the sun has worked.
Old    Steve Oh (olskooltige)      Join Date: Mar 2007       01-28-2008, 5:15 PM Reply
Eraser wheel on a high speed rotary tool will pull all the adhesive off very easily.
Old    Richard (nauty)      Join Date: Feb 2004       01-29-2008, 6:27 AM Reply
You can safely remove the adhesive without ruining the gel coat by following these steps:
- Pull up the Hydroturf/Gator grip
- Spray leftover adhesive with WD-40, let set 45 minutes
- Scrap off adhesive residue with a dull edge (credit card, etc)
- Clean remainder with Acetone (wipe on, wipe off immediately).
I have replaced the matting on my swim platform twice using the above method and it worked great without ruining the gel coat. The above method came straight from Skier's Choice.
