Old    Manzo (zo1)      Join Date: Aug 2002       02-13-2003, 5:05 PM Reply
I am about to drill the hole to mount my paddle wheel assembly. Here is the question:
In the PP instructions, it says to drill a 2" hole. On the BU owners site and on a few posts in this forum I have seen folks say to drill a 1 3/4" hole.
I have yet to measure the assembly itself, but I was still wondering what everyone else did. How big should the hole be?
Thanks All
(Message edited by zo1 on February 13, 2003)
Old    kschroeder            02-13-2003, 5:14 PM Reply
Whatever the instructions say.. It wouldn't hurt to measure the unit either. I believe that it is 2" though.
Old    Darren Yearsley (ralph)      Join Date: Apr 2002       02-13-2003, 5:39 PM Reply
Drill a 4inch hole that way you will have plenty of room to get it through.
Old    never2old            02-13-2003, 6:11 PM Reply
I just installed a system on my boat, used a 2" hole saw. I agree with Ken above, measure the paddle wheel housing to verify the hole diameter. Good luck, drilling the hole is the toughest part.
Old    Bobo (baja)      Join Date: Apr 2002       02-13-2003, 6:20 PM Reply
I believe I drilled a 2 hole per the Perfect Pass instructions. You definitely want to error on the larger size because its a lot easier to seal the void then trying to take another away from the existing hole. Just make sure when you are drilling the hole to hold the drill at the same angle as the hull, this will ensure a flush fit with the paddle against the surface.
Old    JCrave (s4inor)      Join Date: Mar 2002       02-13-2003, 7:10 PM Reply
They switched to a new paddle wheel a few months ago. That's why the instructions have changed from what is posted on MBO. The 2" size is most likely correct for your paddle wheel, but measure it just to be sure.
Old    Manzo (zo1)      Join Date: Aug 2002       02-14-2003, 11:30 AM Reply
Thanks for all your help!!!
