Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through January 18, 2008
Old     (harris)      Join Date: Jul 2007       01-18-2008, 8:48 AM Reply
what do u guys think?
Old    Craig Cox (wakedoctor)      Join Date: Dec 2004       01-18-2008, 9:06 AM Reply
I had the JetPilot A-10 and wasn't to impressed with the whole comp vest trend. I had rather just have something that is approved and floats me. I ride the Hyperlite Agent now. It has the same features as a comp vest such as a snugg fit and allows full arm movement, but also a little more flotation in the front to keep an injured boarder face up.
Old    Nacho (denverd1)      Join Date: May 2004       01-18-2008, 9:08 AM Reply
Gooru and baller are what i wear. not sure whats out for 08, but those are solid vests. baller will float you pretty good. gooru, a bit less, but enough to float your noggin.
Old    Cason Slaughter (caseman1322)      Join Date: Sep 2007       01-18-2008, 9:48 AM Reply
jet pilot A-10 is nice and you don't the lack of flotation if you stand on top of the board in the water but I guess it's the life saving aspect of a life vest that is important. Honestly, the most important thing would be a third person in the boat. That should never give you a reason to not wear a vest but it makes it a little safer if your only wearing a comp vest. The baller is actually more comfortable but I like the look of the A-10 better.
Old    D.F.T.R. Josh (downfortheride)      Join Date: Jun 2005       01-18-2008, 10:39 AM Reply
I rock the A-10 vest and have no problem with the flotation, then somebody posted to get in the water and let all your air out and don't move, I sunk like a rock! I really like the feel of the A-10 but when I need it to it will not keep me above water. I really want to try the Gooru and see how it feels and floats. My next vest will be CGA...
Old    michael z (absoluteboarder)      Join Date: Aug 2002       01-18-2008, 10:45 AM Reply
....another a-10.........fits me like a glove...comfy and not bulky or tight or loose.....and it does lessen the impact to some degree (thats only from the sense I get.....I had some crashes that I feel would normally have knocked the wind out of me , but not with the a-10)
Old    JMB (jbarber3orange)      Join Date: Aug 2007       01-18-2008, 11:16 AM Reply
I think the gooru looks the coolest, I wore a jet pilot falcon last year and its comfy and floats ok for a comp vest. I'm trying the billabong sanford vest this year.
Old    Luker (xbones)      Join Date: Mar 2007       01-18-2008, 11:25 AM Reply
Helium Swat = Sex for your upper body.
Old    J Cas (jcas)      Join Date: Apr 2007       01-18-2008, 11:51 AM Reply
I am a fan of the A-10 as well. The Baller is too bulky for me.
Old    Josh B (joshugan)      Join Date: Apr 2005       01-18-2008, 12:38 PM Reply
A-10 is garbage, imo. Sure it's comfortable but so is not wearing a vest at all. I thought it was great but I took a really bad fall and after not surfacing, panicking, and finally swimming to the surface I never wore mine again.
Also, there was a death last year from someone wearing an A-10 and it not floating him when he was knocked out.
The Xcel Method is an awesome Non-USCG vest. It is segmented and has a thinner foam layer on the upper part of the vest. The lower part has thicker foam which provides pretty good flotation. My experience with the Method is that it won't pop you up quite as fast as a USCG but it does the job in ample time.
Old    Josh T (intotheflats)      Join Date: Oct 2006       01-18-2008, 1:17 PM Reply
I just got one of the new Helium CGA vests, best vest ever. Range of movement is like a comp vest but floats really well. The only complaint I have is that a lot of the flotation is on the chest and back, which kind of makes it bulky. But it's still a sweet vest and really comfy
Old    Rocky Cathey (cmcathy1)      Join Date: Dec 2007       01-18-2008, 1:27 PM Reply
I ride with the A -10 and it's great, it fits and feels awesome. It floats fine...as long as you're conscious.
Old    liquid ryder (pilot_ryder)      Join Date: Apr 2006       01-18-2008, 1:31 PM Reply
oniell check vest sweet,
i wear a vapor, way better floatation than an a-10 and it looks like a bullet proof vest
Old    Nacho (denverd1)      Join Date: May 2004       01-18-2008, 1:46 PM Reply
not to be the pain in the ass of the group, but you should all do the test DFTR josh is talking about. no board, no air. see if you float. just so you know... stay safe.
I HATE WINTER
Old    Al - Pal (watson_134_lf)      Join Date: Nov 2007       01-18-2008, 2:12 PM Reply
i wore the a-10 last year, and the zipper broke, but i liked it.
i have the guru now and its amazing. it feels like your wearing nothing. definatly like it better than the a-10
Old    Josh (romes)      Join Date: Sep 2006       01-18-2008, 2:14 PM Reply
O'neill Outlaw
most comfortable vest i've worn out of all of the above mentioned...i'm gonna get a Gooru as well
Old    Dustin Yost (dyost)      Join Date: Jan 2007       01-18-2008, 2:23 PM Reply
I like the LF Hinge. It's segmented so you can move well and has large arm holes. It's not as bulky in the upper chest and back areas like some of the JP and Oneil approved vests.
FYI, an CGA wake vest will not float you face up, nor are they required to. There are different CGA classes, the class that wake vests fall into only has to keep you on the surface with your lungs full of H20.
I used to ride a non approved vest until I tried the "breathe out" trick. To each his own but I just don't risk it cause the hinge doesn't limit what I can do on the water.
Old    backside (tsbs7)      Join Date: Jan 2008       01-18-2008, 2:53 PM Reply
i like the outlaw as well
Old    alan owen (owenitall)      Join Date: Jun 2007       01-18-2008, 7:58 PM Reply
as far as looks go, i have an A-10, but i want this one, i think it is the sickest looking one ever.
Old    j j (shua789)      Join Date: Mar 2007       01-18-2008, 8:46 PM Reply
oneill boost
Old    Jay (ironj32)      Join Date: Jan 2007       01-18-2008, 9:20 PM Reply
i love my oneill vapor.
Old    Bart Urban (bartush)      Join Date: Jan 2007       01-18-2008, 9:58 PM Reply
i have the Ronix comp vest. fits me very snug, love it. I had a Jetpilot A-10 before it and i must say that the ronix vest was a lot more forgiving on hard landings.
