I have to disagree about the larger cut and harder setup times. I have no problem taking almost no cut, it's all in HOW you edge. You put the board on edge, and if it takes a while to get on edge, that's up to the rider to compensate for with harder edging and better technique. It just takes a little adjusting, but there's no reason you should have to take a bigger cut because a board doesn't "edge right away" you just need to change it up from a board that gets on edge super quick.
