Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through January 12, 2008
Old     (tl7)      Join Date: Feb 2005       01-05-2008, 2:22 PM Reply
I have a 750lb sac that has the connections on the end for hoses, but I need to plug them as they will not be used in the integrated system. Problem is, there is lock-tite or something on the threads. I've tried heating it up to break them loose, but I almost burned the sac in the process and they wouldn't budge at all. Any ideas at all? If it helps at all, it looks like blue lock-tite was used.
Old     (tinytdubb)      Join Date: Jul 2007       01-05-2008, 3:48 PM Reply
http://forums.basspro.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=15;t=001988
Just an idea. I know they aren't using it on plastic threads. I would definitely be careful.
Old     (tl7)      Join Date: Feb 2005       01-05-2008, 3:56 PM Reply
I will give it a shot. How in the world did you run across that?
Any other ideas?
Old     (packrat)      Join Date: Mar 2005       01-05-2008, 4:35 PM Reply
Well if you can't get it off use a fly high quick connect and plug it with a piece of 3/4" hose.
http://www.wakeside.com/category/boat/ballast/ballast_fittings.do
Old     (tinytdubb)      Join Date: Jul 2007       01-05-2008, 7:57 PM Reply
Lol god bless Google!
Old     (04outback)      Join Date: Jul 2007       01-06-2008, 12:02 PM Reply
Call Fly High..>They'll explain how to heat it up with a hair dryer and what to do to remove. I called and they walked me through it.. Takes about 10 minutes to do.. you think you are tearing it up, but it works..
Old     (acurtis_ttu)      Join Date: May 2004       01-07-2008, 6:15 AM Reply
^^^^ did the same thing, it works great, but you really have to keep that hair dryer on their for a while.
