Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through January 18, 2008
Old     (truebeachbum)      Join Date: Oct 2006       12-28-2007, 2:34 PM Reply
the flex it the plate makes them not fit will they take them back and have they fixed the problem
Old     (sidekicknicholas)      Join Date: Mar 2007       12-28-2007, 3:01 PM Reply
i just added a washer under each screw and mine are fine...but i think i read you can get the 08 plate swapped out for free and that'll fix the prob.
Old     (tnctryboy)      Join Date: Aug 2006       12-28-2007, 3:48 PM Reply
i just got a pair of 08's last night and i put washers under the screws also. but if i can get the plate changed out that would be even better.
Old     (jwat142)      Join Date: Jan 2002       12-29-2007, 6:08 AM Reply
I just sent back my '07 ones and they switched out the plates under warranty.
Old     (robertr720)      Join Date: Aug 2007       12-29-2007, 7:18 AM Reply
If you have the 08s then you already have the new plate Shawn. Are the new ones flexing as well?
Old     (tnctryboy)      Join Date: Aug 2006       12-29-2007, 9:33 AM Reply
yea there was no flex just the bolts were to long..... i can't wait to ride in them went from liquid force metros to the Oxfords....
Old     (robertr720)      Join Date: Aug 2007       12-29-2007, 10:04 AM Reply
I'm not sure if I read your post right but if you are just trying to get the screws tight then you don't want to put the washers under the plates. You want to put them between the plastic washer that should have come with the boots and the screw itself so that you don't damage the board or the plates. Unless you got the thumb screws in which case I would see if you could get the phillips head screws cause the thumb screws have had the tendency to break making it a pain to get them back off without pliers.
Old     (tnctryboy)      Join Date: Aug 2006       12-29-2007, 10:18 AM Reply
that is what i did i put them between the large washer and the plastic one and i am using the phillips ones.
Old     (robertr720)      Join Date: Aug 2007       12-29-2007, 10:23 AM Reply
Oh well I guess I did read the post wrong. MY bad
Old     (tnctryboy)      Join Date: Aug 2006       12-29-2007, 10:25 AM Reply
it is all good i am just stoked to get out there in these... my feet will be thanking me.
Old     (wakemitch)      Join Date: Jun 2005       12-29-2007, 10:31 AM Reply
Robert, ronix screws are a little long for liquid force boards. what we do at the shop is flip over the ronix washer and its perfect.
Old     (robertr720)      Join Date: Aug 2007       12-29-2007, 11:16 AM Reply
Nice, that always works. I usually just through on another washer when someone wants to pair those items up or the same thing for Hyperlite bindings. I will keep that in mind for a quick fix though.
