Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       12-26-2007, 9:11 PM Reply
So I got some ballast switches from my local MC dealer and the switches only have 4 terminals on them like this
(Message edited by lovin_the_wake on December 26, 2007)
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       12-26-2007, 9:13 PM Reply
Old    sydwayz (sydwayz)      Join Date: Mar 2003       12-26-2007, 10:13 PM Reply
One terminal should be a ground. ( if lighted switch )
Then you have 2 travelers and 1 feed or load.
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       12-26-2007, 10:37 PM Reply
How would you wire it for a reversible pump ? and yes they're lighted
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       12-26-2007, 10:46 PM Reply
ok well I finally found the schematic on another thread
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       12-26-2007, 10:56 PM Reply
Old    Brad (cool232)      Join Date: Jan 2006       12-27-2007, 5:45 AM Reply
I bought those switches and found they are the wrong ones, they are for acc. switches the ballast switches have seven terminals on the back to fill and empty. check with your MC dealer.
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       12-27-2007, 7:48 AM Reply
That's kinda what I was thinkin' but I'm gonna wire one up outside of the boat and test it to see if it will work
Old    Mikeski (mikeski)      Join Date: Aug 2003       12-27-2007, 10:10 AM Reply
That's a single pole double throw (SPDT) switch with illumination. It will work with relays as you have shown in your diagram.
If you want to avoid the relays you will need a double pose single throw (DPDT) switch rated for at least 20A.
Obviously you are using impeller pumps right?
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       12-27-2007, 10:39 AM Reply
Yea they're reversible simer pumps . . . The switches are 20a and the relays are 30a that should be OK shouldn't it ?
Old    Trace (trace)      Join Date: Feb 2002       12-27-2007, 11:30 AM Reply
Hah, I drew & posted that schematic and posted it in about 2001. Dane modified it to get rid of my unnecessary diode and reposted it, and I've seen it a hundred times since. Cool.
It works for reversible pumps, and is a lot better because it keeps the high amp wires short and out of the dashboard. Just add up the amperage of the pumps that are on each set of relays. They draw about 12A each.
Old    Montgomery (lovin_the_wake)      Join Date: Jul 2007       12-27-2007, 11:40 AM Reply
Yea dude that's awesome I'm so glad I found that I was about to take the switches back and order the DPDT switches until I found your schematic :-)
