What's up all? We've got a 2005 23lsv with a couple hiccups that need to be taken care of before this weekend. I'm hoping you guys can help, you always do.... 1.) The temp is reading at or below 80 degrees the whole time. The exhaust manifolds and exhaust water are pretty much cold. I'm thinking the thermostat is probly stuck open. Any other suggestions? 2.) The belly tank's empty pump is mounted right in line with the center drain plug, and after a couple years of riding, the tank has worked its way back so that the pump is very much in the way of putting the plug in. I was thinking either pull the front ballast out and see if I can get to it that way or putting a bottle jack between it and the gas tank and pushing it back. Once again, I'm open to ideas here. Thanks in advance
