Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 29, 2007
Old    spencer heywood (spenchey)      Join Date: Dec 2006       11-15-2007, 8:09 PM Reply
I'm thinking about getting a roam. My problem is that i would like to have a pair of bindings for the board with out switcing them on and off my wakeboard. I was wonder what you guys would recomend for a fairly cheap but comfortable pair of bindings. I'm looking to spend somewhere between 100-150 dollars.
Old    tommyc (tommyc)      Join Date: Nov 2003       11-15-2007, 8:15 PM Reply
Check out www.BoardersBestBuy.com
Old    Jason Callen (westsidarider)      Join Date: Feb 2003       11-15-2007, 8:25 PM Reply
buy a brand new pair of bindings that are a year or two old. i ride the stiffest bindings possible but the roam is the only board i ride so i need the support wake to wake. when i hit rails or just mess around ill leave my bindings untied and completely loose
Old    Caleb Rountree (dlwsrider)      Join Date: Apr 2007       11-15-2007, 8:30 PM Reply
i find that boards like the Roam or Covenant are more fun on a pair of not-so-stiff bindings, but its preference for sure
Old    Ben Ax (hawkeye7708)      Join Date: Feb 2007       11-15-2007, 8:42 PM Reply
JUST TO LET YOU KNOW! GET THE ROAM BINDING SCREWS! THEY MAY COME ATTACHED TO THE ROAM, IF NOT, ASK FOR THEM! They have a different depth than your standard Claw bolts. Just thought i'd let you know. You probably already knew that, but i figured i'd be the public service annnouncement guy haha
Old    Nick Farrell (nickdakoolkat)      Join Date: Sep 2005       11-15-2007, 9:52 PM Reply
^^^^ Or you could just use washers...
Old    Ben Ax (hawkeye7708)      Join Date: Feb 2007       11-15-2007, 10:53 PM Reply
that'd work for the regular claw thumb screws, but aren't the screw-head claws shorter? i dont think it'd work for them...i could be wrong though
Old    JMB (jbarber3orange)      Join Date: Aug 2007       11-16-2007, 9:22 AM Reply
The roam binding itself is low cut and allows for a lot of movement. I had a cheap pair Hyperlite Spins that I threw on my roam board, works fine.
Old    spencer heywood (spenchey)      Join Date: Dec 2006       11-16-2007, 12:16 PM Reply
no Ben i did not know that, thanks for the warning. GO HAWKS
Old    Tyler McCurdy (tyboarder03)      Join Date: Nov 2003       11-16-2007, 12:49 PM Reply
I use 05 Sphynx's on my roam.
Old    Jeremy Byrom (wakerider111)      Join Date: Jul 2006       11-16-2007, 12:57 PM Reply
ANOTHER SCREW LENGTH SOLUTION
use a sander/ grinder to grind the bolts down a bit... i did it once with different company of binding (liquid force on a hype board)
Old    WAlove (masonwakerider)      Join Date: May 2003       11-16-2007, 12:58 PM Reply
i like stiff bindings on my roam, gives more of a snowboard feel, good for cranking turns and more support on flat landings.
I've ridden with softer bindings and it gives more a of a skatey feel
Old    spencer heywood (spenchey)      Join Date: Dec 2006       11-16-2007, 6:25 PM Reply
i'm looking at getting the liquid force fusion boots. Does anyone use these? How comfy are they, i normally ride the ultra. I like boots with higher support, but the comfort level is my biggest concern.
Old    Jason Callen (westsidarider)      Join Date: Feb 2003       11-16-2007, 8:51 PM Reply
go to your local shop and try them on. i would never get a board or bindings without tryin them on at least once or riding the board once
Old    spencer heywood (spenchey)      Join Date: Dec 2006       11-17-2007, 11:22 AM Reply
idk have a liquid force dealer near me so it will be ordered off the net.
Old    John Jeffries (jdj)      Join Date: Mar 2005       11-18-2007, 11:19 AM Reply
Anything hyperlite would work well.
Old    KG - WakeboardNJ.com (wakescene)      Join Date: Feb 2001       11-19-2007, 9:21 AM Reply
Spencer,
Try the Liquid Force Suction or Ultra Sux for the Roam. Find a used pair on ebay or here and you should be good to go. Both these bindings are no gimmick.
Old    benj_t            11-22-2007, 1:33 PM Reply
LF has some really cheap bindings for 08 that are in tha $100 range on www.wakeside.com im pretty sure...
