Old    asaf alperovich (asaf007)      Join Date: Jan 2006       11-15-2007, 9:55 AM Reply
i herd that some wakeboat can upgrad their prop...to some better performec prope.
if ther is whats is best for X45.2007 ENGINE 350 hp 5.7 INDMAR mcx?
Old     (1boarder_kevin)      Join Date: Mar 2007       11-15-2007, 10:38 AM Reply
What prop do you have now?
Don't know for sure, but I would guess you have the 14.25 x 14 OJ. If so, you problably won't do any better with another prop.
You could always call OJ or ACME and they would tell you your options. Both companies do a good job and will work with you to get you what performance you want (within the engine's power and size of the boat).
Old    asaf alperovich (asaf007)      Join Date: Jan 2006       11-15-2007, 3:42 PM Reply
thanks kevin
Old    Kris (misfits1981)      Join Date: Aug 2007       11-15-2007, 4:14 PM Reply
Probably not going to get any better than the stock one. The size should be a 14.25 X 14.5 120 cup.
Old    rodney (azwakekid)      Join Date: Apr 2005       11-15-2007, 5:05 PM Reply
wow the one i ride behind has a 14.4 x 22. yes it is a slug out of the water. and its got the 496 in it
Old    Kris (misfits1981)      Join Date: Aug 2007       11-15-2007, 5:52 PM Reply
Rodney, The 14 X 22 should be the right prop for the 8.1 big block.
Old     (1boarder_kevin)      Join Date: Mar 2007       11-15-2007, 6:30 PM Reply
Kris,
I thought that the xstar and larger boats used the 14.25 x 14 while the smaller boats used the 14.25 x 14.5.
asa007,
Look on the center of the prop and see what size it is. It is stamped around the shaft. If it is the 14.25 x 14.5, you could go down to the 14.25 x14 to give you more power coming out of the hole but you will give up top speed.
(Message edited by 1boarder_kevin on November 15, 2007)
Old    Tickle (showtime)      Join Date: Nov 2005       11-15-2007, 7:22 PM Reply
you will never tell a difference between the 14.25x14.5 and 14.25x14 -- the difference is barely noticeable on paper, much less in a boat--at best go w/ more diameter--
