Old     (phunnel)      Join Date: Aug 2007       11-06-2007, 10:15 PM Reply
Hey guys, i'm looking at importing a 96 Sanger V210 into Canada from California in the next couple weeks and the seller told me that fuel gauge doesn't work. He basically just keeps it topped up. How hard is it to fix and what would be involved in figuring out what the problem is with it.
thanks
Old    walt            11-07-2007, 5:38 AM Reply
It's most likely the fuel sender. Pull the back seat and you should be able to access the sender fairly easy.
Old     (peter_c)      Join Date: Sep 2001       11-07-2007, 6:06 AM Reply
Ground the sender terminal at the fuel sending unit. With key on if fuel gauge moves it is the sender. If not it is the wiring or gauge. Move to the front and repeat grounding procedure.
If the sender is bad, then the length of time needed for replacement is determined by the location and accessibility of the fuel tank. skidim.com should stock the parts needed.
Old     (sparks426)      Join Date: Dec 2003       11-07-2007, 1:50 PM Reply
Couple hour job, not overly difficult just time consuming. Had to replace the one in my 2000 V210 this summer. Sender float had a pinhole and was staying at the bottom. Had to pull the rear seat out, drivers seat base, one vent hose (under observers seat), and part of the front observer base in order to get the center floor piece out. Tank and sender were then easily accessible. Peter has you covered on figuring out what is wrong, I bought a universal from West Marine and confirmed the ohm range was consistent.
Old     (yubasanger)      Join Date: Jul 2007       11-07-2007, 4:58 PM Reply
Correct me if I am wrong but should be a black deck plate in middle of floor. If so remove the plate by popping it out with a large flat blade screwdriver fuel sender will be right there remove 6 screws holding to tank inspect arm and float some floats are hollow so shake float and make sure no fuel is inside. More than likely the potentiometer is bad on the float you can check this with a cheap ohm meter the range should be 30 ohms at empty and 240 ohms at full.
You can test the gauge as peter said by grounding the signal wire the one in the middle of the sender with the key on and see if the needle on the gauge starts to sweep. (Be careful doing this not to let the needle go all the way to full before disconnecting the ground or damage to the gauge will result. The senders are easy to find and make sure that you match the length and bends of the old one so that the gauge will be accurate.
Old     (sparks426)      Join Date: Dec 2003       11-08-2007, 1:54 PM Reply
No deck plate access on my 2000 210, Jason may be lucky and have one on his '96.
Old     (yubasanger)      Join Date: Jul 2007       11-08-2007, 2:47 PM Reply
I apolgise I stand corrected the 1996 v210 does not have a deckplate so you will have to remove the center part of floorUpload
Old    walt            11-08-2007, 3:48 PM Reply
I can see my fuel sender on my 2000 V210 when I pull the back seat.
Old     (yubasanger)      Join Date: Jul 2007       11-08-2007, 4:35 PM Reply
Walt that would make things easy. I thought that only things under back seat was fuel pickup, fill and vent line. But that would make job easy.
Old    walt            11-08-2007, 4:38 PM Reply
Maybe I'm wrong ? I saw a couple of wires going to it and figured it was the sender. The top of it looked just like the brand new sender I have too.
Mine was acting up too last year but decided to start working again before I changed it out.
Old     (rio_sanger)      Join Date: Apr 2007       11-08-2007, 4:42 PM Reply
Yep, my sender is under the back seat also.
1999 V-210
Old     (sangerlover)      Join Date: Sep 2005       11-08-2007, 4:46 PM Reply
My sender on my 03 v210 is also under the back seat.
Old     (rdmb)      Join Date: Mar 2007       11-08-2007, 5:30 PM Reply
My '03 gauge shows full all the time. I immediately thought the sender too. I checked the resistance across the sender terminals and it showed 88 ohms at 2/3 full. I think the sender has a range of 230-30 ohms or close. The trouble shooting chart on Rochester's site says if the resistance is in the proper range, the wiring is grounded between the sender and gauge and the sender should be fine. I haven't traced the wires because they go into the engine compartment and are mixed with a bunch of other wires in a loom. Frustrating to say the least.
I'm sure none of this helps but I had to tell someone.
Old     (typhoon)      Join Date: Jul 2001       11-08-2007, 7:04 PM Reply
Mine stopped also...it was the sender from the tank
