Old    Martin Tank II (poontank)      Join Date: Nov 2006       10-26-2007, 9:29 AM Reply
Does anyone have experience with this pump?
http://www.greatlakesskipper.com/productdetail.cfm?CatID=58&SubCatID=477&ProductID= 7690
Do you think it would work well enough to fill a 650# sack?
Old    Ron T (wakemetoday)      Join Date: Mar 2006       10-26-2007, 10:00 AM Reply
Yes, I bought one on ebay for $14 to fill my 250 lbs. sacs while my tsunami filled the larger ones. However, at that price for another $50 you could get a tsunami pump and cut you down time in half.
Old    Ron T (wakemetoday)      Join Date: Mar 2006       10-26-2007, 10:02 AM Reply
Sorry, I meant to say, "cut your down time in half," not you down time..
Old    Spencer Welch (spencerwakeside)      Join Date: Sep 2005       10-26-2007, 10:51 AM Reply
Thats not a bad deal for a 750gph pump. I have the 1200gph pumps on EBay for $35 shipped. (nice cheap price). For another $20 you could build a faster pump.
Shameless Ebay Plug
Old    Martin Tank II (poontank)      Join Date: Nov 2006       10-27-2007, 11:10 AM Reply
According to my math it would take 5.76 minutes to fill a 600# sack at 750GPH. That seems fairly quick. Should I expect this type of performance from this pump?
(Message edited by poontank on October 27, 2007)
Old    Trace (trace)      Join Date: Feb 2002       10-28-2007, 6:58 AM Reply
The advertised gph specs on pumps are with no hoses attached, and zero lift. The performance drops as the lift height and hose length increases. You're going to have 2-3 ft of lift minimum to get up and over the gunwales. I remember it taking about 10 min for a 750 to fill a 600 lb sack.
It takes my Tsunami 1200's about 5 min to fill a 750 lb, and that's with less lift because they're in a built-in system (but a little more hose length). You can get them from basspro.com for $37 brand new (with the elbow fitting and uncut wires / base fitting).
