Old    James Whiting (liquidrushes)      Join Date: Aug 2007       08-18-2007, 1:47 PM Reply
Hi all, I have been wakeboarding for a while behind a boat and can pull off 360's etc.... However I have not had so much experience on the cable and I would like to know some tricks to try. I can ride the sliders at my local park but I would like to know how to some tricks like raileys etc....
What is the first trick to try????
Thanks in advance.....
JAMES
P.s. I am a kiteboarder and can do raileys and sbends on a kite. Are they really hard on a cable?
Old    Curt Bernstein (curtbernstein)      Join Date: Aug 2004       04-04-2008, 12:13 AM Reply
raleys will be easy for you, and you shouldn't have a problem with doing them in the flats or off of a kicker. try both
Old    Alex Klimowsow (liquid_force24)      Join Date: Apr 2006       04-08-2008, 6:59 AM Reply
its a bit different from kiting so hopefully u should no how to scoop properly from kiting so... come round the corner and start cutting and keep ur elbows bent and at ur side and after about 2-3 seconds scoop... DO NOT DOUBLE CUT
do that and ull have it easy
