I don't use antifreeze and I have never had an issue- just get the water out. Frankly, if you take the hose off the block that connects to the heater, you can blow it out easily without compressed air. Just make sure you get all of the water out otherwise when you fire it up in the spring you'll have a flood under your dash from cracking the coil.
